Question about Marantz New Original VC5000 Remote Control
The unit will not turn on when the power button is pressed.
    Top Expert:
  • Marantz Master
  • 36,279 Answers
Try removal and reinstallation or replacement of the batteries
Posted on Nov 05, 2012
My Panasonic inverter split zircon with r410a blinking the red timer running indoor motor while out door unit not running?
To display memorized error (Protective operation)
status:
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard. 7. The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5
seconds or operating the unit for 30 seconds. 8. The same diagnosis can be repeated by turning
power on again.
To clear memorized error (Protective operation) status after repair:1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
• Temporary Operation (Depending on breakdown status)
1. Press the AUTO button (A beep receiving sound) on
the main unit to operate the unit. (Remote control will
become possible.)
2. The unit can temporarily be used until repaired
Apr 24, 2017 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
Unit will not turn off
Sounds as if the control board took a power surge.
Jul 24, 2017 | Amcor CF14000 Portable Air Conditioner
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
I just refilled my ink cartridges and for some reason the printer still flashes no ink, any ideas?
  1. Press the On (c00636182.gif ) button to turn off the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Connect the power cord to the back of the unit.
  4. Press the On (c00636182.gif ) button to turn on the unit.and hold it down 10 se
this are the usual procedure..some do it by actually power off ..disconnect power cord..hold down the button ..and connect power cord with the button pressed..and after it powers..release the button ..try it both way s..the issue is that you probably used refilled cartridges and it needs to reset the counters..
Jun 02, 2010 | HP DeskJet F380 All-In-One Printer
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
MY 6310 just stopped on me. I have to unplug and plug it back in but stops again. All lights are blinking and it said to RESET POWER.
HP 6310 Reset
There are 3 types of resets in the printer
1.Partial Reset
2.Semi full Reset
3.Full Reset
To do partial Reset.
1. Unplug the power cable and turn off the the unit.
2. Press and hold # & 3 at the same time with out connecting the power cable.
3. While holding the button, connect the power cable and do not the release button for 5 sec.
4.Then turn ON the unit
To do Semi full Reset.
2. Press and hold # & 6 at the same time with out connecting the power cable.
4.Then turn ON the unit.
To do full Reset.
2. Press and hold # & 9 at the same time with out connecting the power cable.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 29, 2009 | HP Officejet 6310 All-In-One InkJet...
Gps 350
Press the Power button on the top right corner of the case.
If unit will not power on, battery may be dead. Try connecting car charger or power adapter to unit.
To charge battery faster, leave unit connected to power adapter or car cord. Press and hold Power button to turn unit off. Screen will show "Going into charge mode."
Jul 25, 2009 | Garmin nuvi 350 GPS Receiver
Reset power
1.Unplug the power cable and turn off the the unit.
3.While holding the button,connect the power cable and do not the release button for 5 sec.
To do full Reset.
Thanks, Joe
May 30, 2009 | HP Officejet 6310 All-In-One InkJet...
Will not turn on, even with power from car power cord
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Apr 28, 2008 | Garmin Forerunner 305 GPS Receiver
Marantz New Original VC5000 Remote Control Logo
43 people viewed this question
Top Marantz Televison & Video Experts
Electro Med Services...
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
