USB HUB 2.0
USB HUB DOES'NT DETECT MY FLASH DRIVE,IPOD,EVEN MY MOUSE.
BUT IF MY IPOD IS BATTERY CHARGE, IT DOES.
do i need a driver?
or any opinion plzzzzz.
    Novelist:
    Scholar:
  • 72 Answers
It sounds like a power supply issue. Your USB ports are designed to supply power to the devices connected to them. In the case of your battery powered Ipod, the Ipod is supplying it's own power which is why it is working.
More information would give me a better chance of helping you. Is this on a laptop or desktop?
If a desktop, is the USB port on an expansion card or part of the motherboard? What brand of computer are we talking about?
Has your USB ever worked? When did it stop working? Is there anything at all happening around the computer that may have caused this (hardware added, thunderstorm, new software, etc.)?
Looking forward to your reply.
Honest1abe
Posted on Jan 03, 2009
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
Why isnt my ipod charging?
iPod's battery doesn't charge
Several things could keep your iPod's battery from charging. The major causes are listed below in logical order. Check each one to see if it's what's keeping your battery from charging.
Low-powered USB port
iPods that connect to USB ports require a high-power USB port.
Keyboards and some USB hubs will not charge iPod. Connect iPod directly to the computer or to a USB AC power adapter. Click here for more information.
Connect directly to computer
If you connect iPod to something that connects to the computer (like a USB hub or FireWire drive), connect iPod directly to the USB or
FireWire port on the computer.
FireWire port on a Windows PC
The FireWire (IEEE 1394) ports on some Windows-compatible computers may not be powered, and consequently won't charge iPod when you plug it in. Check here to see if the FireWire port on your PC can charge iPod.
Your computer goes to sleep
Your computer can only charge iPod when it's turned on and not asleep. Make sure your computer is on and not set to go to sleep when you want to charge iPod. Tip:
Some Macintosh computers can charge iPod even though they're asleep.
If your sleeping computer doesn't charge iPod, don't worry, just wake it and let iPod charge.
hope this helps
Aug 14, 2012 | Apple iPod touch
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB drives Not working
this problem seems mostly with the usb mouse, the best solution is to plug the flash drive in one port and usb in other and restart the computer generally this always works but if it wont work then the best thing is i also did that, buy a 4-port usb hub and connect it with laptop and connect your usb mouse with this port not directly to your laptop and when you like to use your flash drive plug it in the laptop.
this is working with be perfectly and i hope it will do the same at your side.
Mar 23, 2009 | Toshiba Satellite A135-S2326 Notebook
I have a Dell Latitude D600 laptop whose USB port is being used to charge the battery in an iPod Shuffle music player. The laptop shuts down after about thirty minutes of inactivity, preventing the iPod...
You can use a powered USB hub to charge your iPod, MP3 player etc. without connecting to a laptop's computer USB port.
Just connect the mains adapter to the USB hub and then plug your iPod into the hub for as long as you need.
You can also use this hub for your computer/laptop when you need extra USB ports..
Jan 10, 2009 | Dell Latitude D600 Notebook
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Usb problem
Often this is an electrostatic charge problem on usb hub.
To solve it:
On PC disconnect power cable for 30 mins or so from power outlet.
On laptop, disconnect from power and remove latop battery for 15 mins or so.
If it still does not work, then it may be faulty root hub on motherboard.
regards
Mar 19, 2008 | Acer Aspire 5630 Notebook
Printer causes Flash Drive and Ipod to not work
Ipods and the Kodak printer are both high power devices. There are known issues on common intel motherboards with multiple high power usb devices. You may just have this bad luck, and your motherboad printer ipod combo just wont work at the same time. The best advice I can offer you is to get a High Speed Powerd USB hub. Connect either the IPOD or the printer to the hub and connect the other directly to a USB port on the PC.
Good Luck!
Jan 29, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Computers & Internet Logo
473 people viewed this question
David Payne
David Payne
