Remote control stopped working
The LCD stopped reacting to the remote control. The batteries are ok. The LCD can be operated by means of the buttons on its panel only.
    Top Expert:
  • Televison & ... Master
  • 44,045 Answers
If the remote batteries are "ok", have you tried replacing them with fresh ones?
Posted on Nov 05, 2012
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 42 Answers
SOURCE: Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
Posted on Jan 04, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
SOURCE: I have a 19" Genesis LCD TV and I need the Remote Control Code
I have a 22" genesis LCD and can not get my Direct tv remote to work?
Posted on Nov 14, 2009
I reset my Panasonic DMR-EZ45VEBS to default and since then I cannot set it up again. The remote control doesnot react and I have checked the batteries !
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Dec 25, 2014 | Panasonic DMR-ES30HS DVD RECORDER and VHS...
My remote control for Haier tv stopped working, despite good batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 19, 2014 | Haier HL32R 32 in. LCD TV
I have a Philips LCD TV. The remote seems to have stopped working. The TV has power going to it, but I cannot control the volume or select the input with the remote. The controls on the side of the TV...
Take a camera phone and point the remote at the camera, then press a button that you know is working the Tv - you will see a white flash from the remote LED when the button is pressed. If you press a button on the remote that does not work the Tv and you get a white flash from the remote LED when looking at the remote - as if you are going to take a photo of it - then the remote is good and the Tv is faulty. Visa versa, if you don't get a white flash then the remote is faulty.
If the remote is no longer available, then pop it open with a flat screwdriver and wash the remote with a mild mixture of dish washing soap and water. Then let it dry out in the sun until completely dry and then reassemble to try again. I have repaired remote controls in this way for people :)
Jul 31, 2014 | Philips 42PFL3603D/F7 42-Inch 1920 x 1080p...
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote control doesn't work
Have the remote itself first checked---most tv shops have a tester--point remote at it and press buttons and it reacts-----Many digital cameras will react on their display screen in a very dark room in the same way.
If remote itself tests good the set has a receiver that takes the signal from the remote and it may be bad.
Aug 29, 2012 | LG 37LD450 37 in. TV
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Televison & Video Logo
Top Televison & Video Experts
