I cant go anywhere except home.
Use a Garmin 1450 The Garmin Nuvi 1450 can be used while driving or walking. While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets. As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area. Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass. Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections. Input the name of the state or county, if it is out of town. Then tap "Spell city." Spell out the name of the city using the pop up keyboard. Press "Done." Enter the address number and press "Done." Then enter the street name and press "Done." The "Go" screen opens automatically. Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address. Follow the voice prompts and map highlight to your destination. Navigate Using Coordinates Tap "Where to?" and then tap "Coordinates." Tap the coordinate you want to adjust/input a new coordinate. Tap "Format" to choose the right coordinate format for the map you are using. Enter the coordinates. Tap "Next." Tap the green "Go" button to calculate a route. Use the Map Page Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen. Tap the plus or minus signs on the right side of the screen to zoom in or out. Press the spinning arrow in the lower left corner of the screen to return to the main menu. Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn.
Tap the bar across the top with the next direction listed on it to see a list of all directions.
Hope this helps
SOURCE: nuvi 205wt,free map update.
Glad to hear it! :) If you believe I helped you, please rate my solution. Thanks! :)
- Jim
SHARCNET-USA
SOURCE: how do i update my gamin nuvi 200 maps?
Go to Garmin.com and then support. Register your device, and you might get a free update, just make sure that you select the same map that is currently on your device. If you don't qualify for a free update then you can buy it and do the same.
SOURCE: garmin nuvi 200 after upgrading drivers, it keeps
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl (( double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
SOURCE: it says . cant unlock maps.
Follow this below
Click myMaps
Click Manage Maps
Close the document
Regards
Richard.
