Lg 52-l70 ug power on problem
Power won't come on. Switch seems inactive.
  • 8,617 Answers
Replace the power supply board if the power light doesnt light up. If it does the main board would be suspect. You can get the replacement boards from www.tvrepairworld.com
Posted on Oct 30, 2012
How do i unlock my optimus l70
1. Power off device
2. Insert a non-accepted SIM
3. Power on device
4. Go to dial pad
5. Type 2945#*323#
6. Select Network Lock option
7. Enter unlock code
8. Press Unlock or Done, phone is now unlocked
You can purchase an unlock code from a site like UNLOCKLOCKS.com.
Alternately you can pay your service provider to unlock the phone for you.
Aug 13, 2015 | LG Metro PCS Optimus L70 Prepaid...
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
No power on lg washer model wm2032hw
see the causes and fix it. Use the common sense. God bless you
If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video at the bottom of this page. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Sep 22, 2012 | LG WM-2032H Front Load Washer
My sharp aquos 52" power button is blinking blue and won't come on.
power supply which can be ruled out or confirmed with voltage checks on that board.
Aug 31, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
TV clicks but won't come on .
Check for bad capacitors in the power supply section. Sites like www.TvRepairKits.com have power supply repair kits if needed,
Mar 22, 2012 | LG 52SX4D 52" HDTV
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
One lg vu 920 turns off after 5 seconds and the second wont recieve service
  • Keyboard issues (no predictive text):
    • This isn't a "fix" per se, but it seems the best route is to use an alternative keyboard. Swype is pre-installed on the phone, so you can switch to that without installing anything new. Alternatively, you can try other players such as SwiftKey, A.I.type, and TouchPal. Otherwise, LG is aware of the issue and working on a fix.
  • Phone won't charge
    • The potential fix is to enable USB Debugging. To do so, head to Settings -> Applications -> Development -> make sure USB Debugging is checked.
    • Alternatively, if it won't charge normally (while powered on), it should charge while powered off. Your best bet is probably to power it off and let it charge while you sleep.
    • For some people, it seems that the phone actually is charging, it just doesn't show it.
  • Can't use USB storage
Unfortunately, there are no perfect fixes for any of the issues listed above. Other users are reporting a smattering of smaller (and substantially less frequent) issues, but hopefully the above can help some people with the most significant issues.
Mar 02, 2012 | LG Cell Phones
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Oct 25, 2011 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
