Question about Nintendo Professor Layton & the Curious Village Games for DS
00000-0000=33333 use the numbers one to nine once to get the equation 33333
  • 9 Answers
Do you need the answer? if so this is it :
41286
- 7953 or
41268
- 7935
each adds up to 33333
Posted on Jan 03, 2009
I can solve this there are 2 answers
1 is 41268- 7935
or 21286-7953.
good luck
Posted on Jan 04, 2009
2 Suggested Answers
  • 84 Answers
SOURCE: use each of the numbers one through to nine
41268-7935=33333
Hope this helps
Posted on Aug 18, 2009
How do you write 11.2987 in words
I'm not going to do your homework for you, but I'll explain how it's done in general. When you speak a number, you generally say the integer part in the normal manner, say, "point," and then speak the digits of the decimal portion (or, if the decimal portion is that of an irrational number or endless repeat, speak it to the desired number of decimal places). You write the number in words in the same way. For example, 99.995 is "Ninety-nine point nine nine five."
Nov 25, 2014 | Office Equipment & Supplies
What's a number equivalent to 100 using only the number nine
99.9999 repeating is technically equivalent to 100, depending on what level math you're in.
For example, 100 / 3 = 33.3333...
but clearly 33.333 * 3 = 99.9999...
So multiplying both sides of my first equation by 3, we get 100 = 99.9999
If you are not looking for "a number equivalent to 100" but "an equation or set of numbers equivalent to 100", then there are many ways. For example:
99 + 9/9 = 99 + 1
And 99 + 1 = 100
Jan 16, 2014 | RXE160 Equivalent NTE16013-ECG POLYMERIC...
Explain what it means for a system of linear equations to have no solutions, one solution, two solutions, and infinite solutions.
  1. No solutions: The system is incoherent, incompatible Example: 2x+3y=8 and 2x+3y= 15. The two lines are parallel and distinct.
  2. One solution: There exits a pair of values (x,y) that satisfy both linear equations. The two lines on a Cartesian graph have one intersection point.
  3. Infinite number of solutions: The two equations are one and the same (one is just multiplied by some constant). The graph of the two lines yields the same line. One is superposed on the other. Any ordered pair (x,y) that satify one equation (there is an infinity of such pairs) satisfies the other.
  4. Two solutions: cannot happen because the two lines can either intersect once, be parallel, or superposed one on the other.
Dec 13, 2012 | Mathsoft StudyWorks! Mathematics Deluxe...
4x - 2x + 1 = 5 + x - 7
Start by combining like terms on each side of the equation.
Remember, when working with variables the real numbers always come last in the equation(i.e. 5+x-7=x+5-7)
Once you have this completed move all variables to one side and all whole numbers to the other side. Solve from there.
May 17, 2012 | MathRescue Word Problems Of Algebra Lite
What are the equations and its kinds?
Definition
A mathematical statement used to evaluate a value. An equation can use any combination of mathematical operations, including addition, subtraction, division, or multiplication. An equation can be already established due to the properties of numbers (2 + 2 = 4), or can be filled solely with variables which can be replaced with numerical values to get a resulting value. For example, the equation to calculate return on sales is: Net income ÷ Sales revenue = Return on Sales. When the values for net income and sales revenue are plugged into the equation, you are able to calculate the value of return on sales.
There are many types of mathematical equations.
1. Linear Equations y= mx + b (standard form of linear equation)
2. Quadratic Equations y= ax^2+bx+c
3. Exponential Equations y= ab^x
4. Cubic Equations y=ax^3+ bx^2+cx+d
5. Quartic Equations y= ax^4+ bx^3+ cx^2+ dx+ e
6. Equation of a circle (x-h)^2+(y-k)^2= r^2
7. Constant equation y= 9 (basically y has to equal a number for it to be a constant equation).
8. Proportional equations y=kx; y= k/x, etc.
Jun 14, 2011 | Computers & Internet
In complex number mode, how to get out?
"Is there anything that I can do about this to stop my answers being complex numbers when solving cubic equations?"
You are making an assumption that is unwarranted.Namely that a cubic equation must necessarily have 3 real roots. This is not the case.
Let your equation be
If coefficients are complex you should expect some complex roots. Right?
If the coefficients are REAL then depending on the discriminant
you can have three cases
DELTA positive : three distinct real roots
DELTA=0 , the equation has a multiple root and all roots are REAL
DELTA negative: the equation has ONE real root and 2 complex roots that are complex conjugate of each other.
It suffices to look at the Tartaglia/Cardano expressions of the roots to know that more often than not there is going to be complex roots.
May 05, 2010 | Casio CFX-9850G Plus Calculator
If there are 623 students and the ratio of girls is 2 to 3 boys. how many girls are there?
The best way to solve this is to develop one or more equations and then solve for the unknown numbers.
I solved this problem twice using different sets of equations to make sure I was right, and here is what I found:
1) I used the equations x + y = 623, and x = (2/3)y. In these equations, x is the number of girls and y is the number of boys.
Substituting the second equation into the first, I get (2/3)y + y = 623.
Adding the left side together I get : (5/3)y = 623.
Dividing both sides by (5/3) I get 373.8.
This means that x (the number of girls) is 249.2.
2) For the second attempt, I developed the equation: 2x+3x=623. Here 2x is the number of girls, and 3x is the number of boys.
Adding the left side I get: 5x = 623.
Dividing both sides by 5 I get: x = 124.6.
This means that the number of girls (2x) is 249.2. Just like in the first method.
But since you can't have a 1/5 of a girl, the answer must be 249 girls.
Nov 19, 2009 | Office Equipment & Supplies
Excel formula.....
Let's start with the 1st equation. I assume you want to be able to recalculate by changing the number of pages.
Put 65 in cell a1.
360 in b1
In C1, put the formula =a1/b1 that's your book thickness
In D1, put .02 for the cover
In E1, put the formula =C1+D1
Now you can change A1, B1,or D1 and the Total thickness gets recalculated automatically. Be careful not to type numbers into C1 or E1, or you lose the formula.
The same for the other equations - a cell for each number ("variable") and another cell for calculations.
Once you've verified the results, then you can get fancy and add titles above each field to make it easy to remember what goes where.
You may need to change the cell format to control the number of decimal places, or thousands commas. Right click on a cell and select format to see the choices you have.
Keep a backup copy of the spreadsheet in case someone (not you, of course) makes a mistake and overwrites the formula cells. You can also look into "protecting" cells to keep them from being changed.
Hope that helps.
Jul 14, 2008 | Computers & Internet
Maths Equations
-3x+7y=-1 and -2x+5y=0
Jan 17, 2008 | Curtis-Mathis CM25011 25" TV
Nintendo Professor Layton & the Curious Village Games for DS Logo
1,727 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
