Question about Brother MFC 420CN All-In-One InkJet Printer
What does the icon mean for the paper load - Brother MFC 420CN All-In-One InkJet Printer
Try to follow the instruction shows on screen, then also try to fix the tray paper on the right position then press start and see if it works
Posted on Dec 28, 2012
Lamp of chek a paper is light... cannot to print
Hi Good day!! This error means: Paper out or Paper jam. check your printer if there is a blockage that's why it can't print if there is a blockage 1st thing to do is to turn off your printer and then remove such blockage. if there is no blockage load paper check your printer queue box!! to go to your printer queue box. Click "Start" Click "Settings" Click "Printer and Faxes" there you should see your installed printer check the icon status it should be 0 and ready. if not 0 there is a file that did not finish printing. cancel it just right click your printer and then cancel all. if success your printer should be ok now... hope my solution help you THANKS
Oct 15, 2010 | HP PSC 1410 All-In-One InkJet Printer
What does load mp feeder letter mean? There is paper in the printer why is the printer not prinint
load mp feeder means To load the Manual Paper Feeder
You might have selected the printer settings for manual feeding. Hence you need to feed that papers in manual feeding tray.
You can change the settings to automatic paper feeding to get rid of this error.
Aug 27, 2010 | Lexmark Optra T610 Laser Printer
My sharp ar122en copier cannot load paper, please
Does loading mean picking papers? If so remove the paper tray and rotate the semi-circular rubbers . Clean them with a clean damp cloth and return the tray loaded with papers.
May 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Getting message to load tray 1 A4. load with
This problem is commonly found across printers, and is not specific to your printer model.
This problem occurs if:
  • You select the Hold mismatched documents option on the Advanced tab of the Properties windows of the printer.
  • The printer driver user interface (UI) plug-in uses the full UI replacement functionality. This means that printer driver replaces the default Windows printer dialog interface, so Windows fails to find certain registry keys to determine the paper type.
Microsoft has a hotfix for this issue for Vista and Windows Server 2008:
http://support.microsoft.com/kb/971319
If you are seeing this issue on XP, you can do the following:
1. Go to Printers and Faxes from the Start Menu (or type the following command in the Start->Run window: control printers).
2. Right click on the affected printer's icon, and click on Properties.
3. Click on the Advanced tab.
4. Uncheck the option Hold mismatched documents.
5. Some printers have the default paper type as Letter, so please change the printer properties to use A4 as the default
5. Click OK to save the settings change.
6. Wait for 15 seconds, and try to restart your printer job if needed. Usually, Windows will automatically restart the job, once the paper mismatch setting is resolved.
7. Ensure that you make the above printer property settings change on every computer where your printer is installed.
Happy printing!
Jan 21, 2010 | Dell 5110cn Laser Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
What does the forth light mean? and what to do to make the printer pickup the paper as my printer stop as soon as it starts to print.
If you are including the power light, the fourth light relates to loading paper. A steady light means it needs paper, a blinking light wants you to load the paper into the manual feeder. If you are not including the power light, its calling out a paper jam.
Jul 17, 2009 | Lexmark E232 Laser Printer
Not printing
have you tried to replace the ink cartridge?
if ink cartridge is new yet it's not printing, try to print a test page by going to Start>Control Panel>Printers and Faxes, then right click on the printer icon with a check mark on it, select properties.. then click on "Print test page".. if it prints or loads a paper but it's blank, then it means the printer is working, it may have run out of ink..
If it doesn't print, or doesn't load a paper, most likely there's a problem with the software for the printer.. you may have to re-install the printer drivers..
May 09, 2009 | Epson Stylus Photo 1200 InkJet Printer
Paper not loading (but it is)
If it's an older machine, try cleaning the Multi-sensor (next to the printhead with the scissors icon on it).
Mar 12, 2008 | Epson Stylus Pro 4800 InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
