Question about Brother MFC 240C All-In-One InkJet Printer
What side of paper goes in fax, up or down - Brother MFC 240C All-In-One InkJet Printer
  • Brother Master
  • 32,281 Answers
Face down on the glass.
Posted on Oct 30, 2012
When I try to make a copy in My fax sharp ux-108 the paper goes out blank
First make sure the original document is loaded with the correct side facing down. If not the problem try taking out the roll paper and reload it with the other side of the paper facing up
Jan 23, 2012 | Sharp UX 108 Roll paper Thermal Fax
CLX-3185FW I would like to know how to send a fax overseas. Where do I put the paper to be send? Thanks
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
Sep 14, 2011 | RIM Computers & Internet
Do I place the paper face up or down when faxing from a HP 6210xi
Hello
Down,print goes down.
This confuses me everytime.
Apr 11, 2011 | Computers & Internet
No problem, but don't know if the print goes face side up por down into the printer when faxing
Where you put the paper must be a little icon like a page with lines, if you see this put the paper face up. I am surprise you did not check with a fax recipient to see if they got it (Blank paper or the fax)
Mar 18, 2011 | Office Equipment & Supplies
Which side goes up with Canon fax - L220? Thanks
Get a piece of paper, and put a different BIG mark on each side of the paper, big and bold, then run it through, and see which "Side" comes out, and that's your answer. Just press "Copy" to see. Or you could even send a Fax to yourself, and see. Also to help, your manual is below, that too will show you.
wp.no-ip.biz/download/kezikonyv//fax-l295_Users-Guide_ENG.pdf
Jun 06, 2010 | Canon L220 Plain Paper Laser Fax
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Faxing up or down
Look at the hopper. It will almost certainly have a little graphic on it to tell you which way up the document goes.
If it looks like a sheet of paper with lines of writing on, the paper goes in print side up.
If it looks like a sheet of paper with one corner folded over, and lines of writing visible only on the turned over corner, then it goes in print side down.
If you can't find the graphic, then experiment: Take a blank sheet of paper. Write "Up" on one side and "Down" on the other then stick it into the machine so the writing is telling the truth. Most fax machines have a copy mode - use this to see which side of the paper the machine reads (if you can't get it to copy, fax your page to somebody and get them to phone back to tell you which side of the page they've received).
A.
Jan 18, 2009 | Brother Office Equipment & Supplies
Black stripe down one side of every fax
On my Brother fax machine, there is a blue plastic cleaning thingy on the toner cartridge used to clean the metalic wire. If you leave it on the wrong side after cleaning, you get a thin black strip down the edge of every page. Slide it over to the other side and problem goes away.
Jul 08, 2008 | Ricoh 3310LE Plain Paper Laser Fax
Fax
its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Oct 26, 2007 | Office Equipment & Supplies
Brother MFC 240C All-In-One InkJet Printer Logo
13 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
