Question about Seiko Britannica Concise Encyclopedia ER8000 Dictionary
The keys have to be pressed several times before they register on the screen and some of the keys tend to stick.
The register doesn't show the change amount after press subtotal + cash amount + ca/amt tend.
1)Maybe you need to open the keyboard and clean it. It is possible that you subtotal and cash button are registering as Deptments
2)Or you key is not on Reg
Mar 26, 2015 | Retail Supplies
How do I get a grand total for just a department from a Royal 210dx cash register.
Are your departments set up properly?
This is how to check:
Running the Department Confirmation Report
You can print a report that shows the programmed information for a range of departments or for all departments. The range report is helpful if you want to see the programmed names of some of the departments, but do not need to see all the departments and other cash register programming.
You can also print a report that shows department information and sales.
For more information, see Running Management Reports on page 85.
Note:
Unless you specify a department range, all departments print in the
Department Range Report. This will take a few minutes.
To run a department confirmation report:
Programming > Department Set Up > Depart Conf Report
1 Press the Main menu (on) key.
2 Press the Arrow Down key to select Programming. Press the Amount Tend Total <Enter> key.
3 If you are prompted for a Manager Passcode, type the passcode number and then press the Check key. If you did not program a Manager Passcode, go to the next step.
4 Press the Arrow Down key to select Department Set up. Press the Amount Tend Total <Enter> key.
5 Press the Arrow Down key to select Depart C onf R eport. Press the Amount Tend Total <Enter> key.
6 Select how you want to see the report. If you select Display, use the arrow keys to review the report in the clerk screen.
https://www.royalsupplies.com/cashreg/1000ML_Instruction_Manual_eng.pdf
Jan 10, 2015 | Retail Supplies
How to reset date on royal cash register model alpha 710ml
Page 7
To set the date
1 At the prompt, use the rounded Number keys to enter the last 2 digits of
the year. For example, for 2006, press 06. Press the Amount Tend Total
<Enter> key.
2 Use the rounded Number keys to enter the 2 digits of the month. For
example, for February, press 02. Press the Amount Tend Total <Enter>
key.
3 Use the rounded Number keys to enter the 2 digits of the day. For
example, 24. Press the Amount Tend Total <Enter> key.
4 Use the rounded Number keys to enter the 2 digit hour. For example,
09. Use military, or 24 hour, time for hours after 12 noon. For example,
if you want to enter 8pm, press 20. Press the Amount Tend Total
<Enter> key.
5 Use the rounded Number keys to enter the 2 digits of the minutes. For
example, 54. Press the Amount Tend Total <Enter> key.
Using the information in this example, the date and time are set to
02-24-06 8:54pm.
http://www.royalsupplies.com/cashreg/Instruction%20Manual%20A710ML%20Eng%20ver11%20GOLD3.pdf
Sep 17, 2014 | Royal alpha 710ml thermal cash register,...
How to change time on tec ma 1350 cash register
1) key on set 2) press 6 then x(multiplication) 3)enter your time 5)press cash/tend...........Good luck
Dec 08, 2013 | Computers & Internet
I have a Pure One classic radio.When turned on the display screen reads "upgrade (reva) press any key to exit)I press a key but the same screen comes up again.Cannot get any station to play and can...
I have the same problem, and no real solution, although I do find by hitting one of the keys several times in rapid succession, then pressing the standby button, the radio does tend to come on.
Really irritating, though, and I'd love to know how to fix it for good. Good luck - and do let me know if you find a solution.
Gilly
Dec 06, 2010 | Pure Digital The Bug DAB Radio
I have purchased a used Te-2200 cash register. I want to program both the 8 and 5 percent sales tax and also change the name of the business on top. I have been trying all morning with no luck what do I...
To enable edit Company Name
1. Key turn to PGM
2. Press [5] [Subtotal]
3. Press [3][2] [Subtotal]
4. Press [4][2] [CA/AMT TEND]
5. Press [Subtotal]
6. Press [3] [Subtotal]
7. Press [2][1][2][2] [Subtotal]
8. Press [1][7][7][0][7][0][0][0][0][0] [CA/AMT TEND]
9. Press [Subtotal]
Edit ur company name
1. Press [2] [Subtotal]
2. Press [1] [3] [2] [Subtotal]
3. Input Your first line of Company Name (Max 16 Characters)
4. Press [00] [CA/Amt TEND]
5. Press [2] [3] [2] [Subtotal]
6. Input Your second line of Company Name (Max 16 Characters)
7. Press [00] [CA/Amt TEND]
8. Press [3] [3] [2] [Subtotal]
9. Input Your third line of Company Name (Max 16 Characters)
10. Press [00] [CA/Amt TEND]
11. Press [4] [3] [2] [Subtotal]
12. Input Your fourth line of Company Name (Max 16 Characters)
13. Press [00] [CA/Amt TEND]
14. Press [Subtotal]
15. Key turn back to REG1
16 Done
Oct 29, 2009 | Casio Parts Cash Register PC Desktop
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
How to set mn tax on my casio ce-3700
TO PROGRAM TAX PERCENTAGE:
1. TURN KEY TO PROGRAM
2. PRESS 3 ON AMOUNT KEY PAD
3. PRESS SUBTOTAL
4. PRESS 0125 OR 0225 & SUBTOTAL
5. PRESS TAX % WITH DECIMAL POINT (EX. 8.25) AND PRESS CA/AMT TEND
6. PRESS 5002 AND CA/AMT TEND
7. PRESS SUBTOTAL
Jun 28, 2009 | Casio Parts Cash Register PC Desktop
ROYAL ALPHA 587 CASH REGISTER
Try this, for example june 30 2004 =
Put the mode key in PRG position In round number keys press 063002 then press #/ST/NS key
If that works to set the time in round number keys press 1100 then press Qty/Date or 1305 for one 05 pm. I have a 587 cx and can't fiqure out how to print my reports X Z
Aug 21, 2008 | Office Equipment & Supplies
Seiko Britannica Concise Encyclopedia ER8000 Dictionary Logo
43 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
ray gallant
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
