I been using wifi through main computer tg782t bigpond thompson modem with netgear and whilst configuring from phone i accidently ticked do not allow devices which i thought it meant others. Now my phone or main computer can't access anything nor the internet and i have tried fixing it but it's very difficult without the use of the internet. The modem works fine but nothing else. When trying to connect to wifi on phone it says authentication error. Please help if you can fix this problem. Thanks.
  • 7,627 Answers
If I understand your question, it's your Modem thats "locking" you out?
If so, look for a "RESET" button on your modem, usually on the back, it's very small, insert a pen point or similarly small point and hold for 10 sec. or so to reset your modem to default configuration settings. You will have to re-enter a passcode and reconfigure.
Posted on Oct 29, 2012
Testimonial: "Thank you very much for your solution. I will try that tomorrow but my question is once.i have done that how would i know what pin numbers to put in or the right information cause i dont want to make it worse."
  • 1 more comment
  • max carson
    max carson Oct 31, 2012
    You Modem will return to default settings, as in, the wirelesswill be "OPEN" you will have to reset you security code/password key on your modem, I assume NETGEAR, i'm not fimiliar with " bigpond thompson modem "but you can find Netgear set up athttp://kb.netgear.com/app/answers/detail... if you do not already have it. YOUR QUESTION: once.i have done that how would i know what pin numbers to put in or the right information cause i dont want to make it worse." By PIN NUMBER, do you mean your Netgear wireless password/ access code number?
  • max carson
    "FIRST" You can also try to restart everything. 1) unplug your Bigpond Modem, remove battery if applicable, 2) unplug Netgear Modem,3) shut down your computer4) replace battery, if applicable, in Bigpond Modem and plug in AC outlet, 5) plug in Netgear into AC outlet, wait for devices to run"self test"6) turn on computer and check for connection to wireless access point (Netgear) . SHUT OFF YOUR PHONE DURING THIS PROCEDURE, YOUR STATEMENT: whilst configuring from phone i accidently ticked do not allow devices which i thought it meant others. THE "TICK WAS DONE ON YOUR PHONE CONFIGURATION ONLY?
  • josie tassone Nov 01, 2012
    I have all passwords on modem. I'll try what u said and see how i go. Thanks for all your help.
5 Suggested Answers
  • 624 Answers
SOURCE: I cannot get connected to the internet.
If I understand you correctly you currently have a computer connected directly to your ADSL Internet connection and it can connect to the Internet. When you disconnect the computer, connect the DG834G router to the Internet connection and then connect the computer to the router you loose the Internet connection. It sounds like a ?simple? case of the router not being configured correctly. What I would suggest is to reset the router to its default configuration and follow the installation instructions again from the start. I?m not a big fan of the software configuration wizards that these home routers come with BUT they are the best way to easily configure the typical installation. To reset the router: in-between the 4 Ethernet LAN ports and the ADSL port there is a small reset button. Press and hold the reset button until the test LED turn on (about 10 seconds). Release the button and wait for the router to reboot. Let us know if this works or not. If you still have problems the more details and error messages you can supply the better.
Posted on Dec 29, 2006
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Posted on Aug 10, 2008
MaverickIT
  • 53 Answers
SOURCE: setup router with vonage device and dsl modem
For the best call quality, I suggest you connect the Vonage router to the DSL modem, and if necessary, connect the Linksys router behind that. Why are you using a second router, though - you probably just need a switch or hub, if you're trying to connect more machines. Small networks rarely require more than one router. MaverickSolutions.biz may be able to provide additional support if you can give us more details about your installation.
Posted on Jul 21, 2009
  • 60 Answers
SOURCE: DSL connection not being shared by Linksys RV042 Dual Wan router
Looks like your "modem" is actually a gateway, as is common with DSL devices. It's acting like a modem and a router. So you're actually connecting a router to your RV42. You could get this to work a couple ways.
1. Leave the modem acting like a router and configure the WAN connection on the RV42 as a static IP, and use the IP of the modem. You may also be able to use "obtain IP automatically" in the WAN connection. This way, the modem stores your PPOE information and just forwards the traffic to the RV42. Any devices behind the RV42 won't know the difference.
2. Configure the modem as just a modem (no routing). Your ISP should be able to talk you through this, but in the modem configuration you can look for what's usually called "bridged mode." Then you would enter the PPOE information in the RV42. This is my preferred method.
Posted on Jan 27, 2010
NIC Driver for TG782T modem
Firstly, can you tell us what version of operating system are you using? Windows XP onwards usually have the WIA drivers included, unless a absolutely new chipset! Or is it a Realtek R8111/8168/8169 network interface? You can download on another computer the driver kit from Realtek directly.
Aug 06, 2014 | Thomson Computers & Internet
I need to use my telstra thomson TG782T modem on a different network how do i reconfigure it??
You need to contact your 3rd party service provider for the configuration settings for their network.
If you cannot change the settings on the Thomson modem then maybe the firmware is set to Telstra's network and cannot be changed. In this case you need to use the recommended modem suggested by your 3rd party service provider.
Apr 20, 2013 | Computers & Internet
Tg782t modem is this adsl2+ (BIGPOND TELSTRA AU)compatible ?
If it's connected to your computer via ethernet cable then you have nothing to worry about. But if it's connected via USB then check with the label on the modem if it is compatible otherwise your OK.
Apr 26, 2011 | Computers & Internet
We are having trouble getting xbox live we have a wirless thompson TG782T it says we nead to change the MTU setting.Bigpond and telsta have been no help and say that we shouldnt have to change the Mtu...
Set your console to have a static IP address.
Make it something like 192.168.1.84 (where 84 can be anything from 2 to 250, so long as it is not the same as any other device)
Subnet mask, 255.255.255.0
Default gateway 192.168.1.254
DNS 192.168.1.254
MTU 1500.
If this doesn't fix it, try
10.0.0.150
255.255.255.0
gateway 10.0.0.138
DNS 10.0.0.138
MTU 1500
~KenjiFox
Jan 07, 2011 | Computers & Internet
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
I have just connected a ThomsonTG 782T router and I cannot get my file share Shareaza to go. I have tried to fix ports with no luck - what do I do? I was able to do it to my old DLink GST604T wish I had...
Hi - I received the Thomson free with my signing up with Bigpond. The IP address in my computer 10.0.0.2 would not come up on my browser. I typed in to google thomson TG782T user manual (which I did not get with Bigpond) there I found the Thomson IP address 10.0.0.138 - and when I typed in that it connected to be browser (but it is 10.0.0.2)_ they have configured it to stop anyone disabling the firewall and also not to be able to use VOIP. I think my only solution is to buy another modem/router and wish I had stayed with my DLink GS...........Regards, Robyne
Jan 26, 2010 | Computers & Internet
Port forwarding tg782t to allow remote desktop
your firewall might have an Intrusion Detection System (IDS) which locks your network if programmed to detect unwanted ports. Work on your firewall first. hope this helps..
Aug 16, 2009 | Computers & Internet
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
I have just relocated property & Iam with Bigpond & have always been with bigpond & when I try to connect to the internet I get an I-primus pop up saying modem misconfigured - bad username or...
If you are using a usb dsl type modem and not a modem/router for connection, go into internet explorer>tools>internet options>connections tab, then look to see that Bigpond is selected as the default dial up.
If you are using a modem/ router which in effect is on all the time, go into the same menu in IE but tick the liitle button saying never dial a connection.
Sep 15, 2008 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
