Question about Intel Essential DG41WV Desktop Motherboard - Intel Chipset BLKDG41WV
Display problem monitor doesnot get any signal after cmos resetting
  • Intel Master
  • 27,725 Answers
One bad or faulty lead connection can cause a computer to continue restarting on a cycle or to shutdown or fail to detect your hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
if you are able to get a screen
Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If you computer came with a motherboard disk the drivers could be on it
or you might need to download them
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name vga driver you might have to try a few times to get it right
hope this helps
Posted on Oct 30, 2012
Changed cpu on packard bell imedia d3318, still getting no signal on monitor and no beeps. When I remove the cpu and power on, there are no beeps
Have you check with different RAM, Did you try to reset BIOS by removing the CMOS battery and shorting CMOS jumper? Your Processor may be ok but you are plying with it. When there use to be no display then first thing you should doubt with the CMOS battery and the RAM and Motherboard, rather then CPU, CPU hardly gives problem.
Aug 14, 2012 | HEWLETT-PACKARD Computers & Internet
No signal on monitor, keyboard num key not on/off CPU is running
some bios problem try reset bios given method
The easiest way to clear the CMOS is to enter the BIOS setup utility and choose to "Reset BIOS Settings" to their factory default levels
Yet another way to clear the CMOS is to reseat the CMOS battery. By removing and then reinstalling the CMOS battery, you remove the source of power that saves your computer's BIOS settings.
apply any method and try
May 19, 2012 | Computers & Internet
Our screen has suddenly turned "reddish" in color. Cannot adjust this from the computer or on the monitor itself. Any suggestions?
hi
1st try display drivers just reinstall if not then you have a problem with your motherboard u have lost your display from motherboard
you have to go for new display card
Jul 09, 2010 | Computers & Internet
My mobo doesnt beeps nor video output
your bis/firmware will be corupted.download latest firmware in bootable cd format and update bios.even if mb doesnot give display it can boot and flash the bios.(follow website for details on how to make cd-iso)
May 27, 2010 | Biostar MCP6PB M2+ Motherboard
CPU is running but no diplay in Monitor
CPU is running but monitor is not display. Prevoiusly it was worked suddenly it happened.
Apr 01, 2010 | ASUS P5PE-VM Motherboard
try resetting the bios on the motherboard. The bios jumper is usually located near the battery(CMOS battery). If you can't find the CMOS jumper, just try to remove the CMOS battery and put it back again. This will reset everthing.
Mar 28, 2010 | Gateway GT5622 PC Desktop
No video output
I'm glad resetting the CMOS fixed it. (Posted as solution so you can rate the response.)
Mar 22, 2009 | EliteGroup NFORCE 570 SLIT-A Motherboard
NO SIGNAL TO MONITOR
change the memory card, then reset the cmos. if problem persists change the video card, its probably bad.
Jan 24, 2009 | Intel Motherboard
Green display for intel d102ggc2
joukanrar
r u check ur monitor with other pc. if not then at first open CMOS setup (BIOS setup in intel board) and watch that it also with green display or not if it also green means ur system is ok. now just problem is in monitar signal cable ( one of video signal wire brackage) or vga connector.
if it is(CMOS setup screen) not with green display then problem with ur video driver. uninstall this driver and again install it.
thanks
Buddhadev
Jul 04, 2008 | Intel D102GGC2 Motherboard
Intel Essential DG41WV Desktop Motherboard - Intel Chipset BLKDG41WV Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
