Question about Sony Playstation 3 (PS3) Console
System saying hard drive corrupt
Turn system on and it keeps saying hard drive corrupt
  • 1,472 Answers
Bully3724
If you are getting a corrupted hard drive messsage on your PS3 this means that you have some bad data on the hard drive or the drive is bad. The link below will help you address this issue. If you still have trouble then you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Nov 10, 2010
KEEP SAYING I DO NOT HAVE A HARD DRIVE when i do
turn the power off and reseat the hard drive and turn it back on to see if the system will see it. Also make sure you can hear the hard drive spin. If it doesn't after you reseated the hard drive you might have to buy a new hard drive.
Mar 03, 2011 | Microsoft Xbox 360 Console
Playstation 3 (PS3) Console: PS3 KEEP SAY DISK FILE SYSTEM IS CORRUPTED WHAT TO...
Guest
If you are gettting the corrupted drive message this means that you have corrupted data on your hard drive. The link below will help you address this. If you still have trouble then most likely you will need to replace the hard drive.
Issken
May 16, 2010 | Sony Playstation 3 (PS3) Console
Hard disks file is corrupted
Has it asked you to reformat the hard disc? If you have tried that and it still doesn't work then you may need a new hard drive. Don't worry, for $20-$50 (US) you should be able to fix it. Without knowing what happened before that it's hard to say. But my best guess is that the hard drive is internally damaged in some way. Just take off the small panel on the left side, remove the screw, use the little handle and gently pull to the right then out. It should be a Seagate SATA hard drive 20, 40, 60, or 80GB. Just buy a new one from your local store or online. Make sure that you mark the bad one before you get the new one near it so you don't get tem mixed up. Then remove the 4 little screws on the mountinng cage, switch hard drives, install back into PS3 and it will give you the format screen again. Click yes and it will format, turn off, back on, and you should be all set!!
May 04, 2010 | Sony Playstation 3 (PS3) Console
Hard disc corrupted on my p3
etha125
If you are getting the corrupted drive message this means that you have corrupted data on the hard drive or there is something wrong with the drive its self. The link below will help you address the corrupted data.
Issken
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
Keep getting amessage saying hard disc corrupted.
Sounds like your hard drive is so badly faulty that it cannot be restored, in all likelihood you will need a replacement drive.
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Hard Disk Corrupted
you need to send the ps3 to sony so they can reset the hard drive and format the system
Dec 11, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
I start up my computer, I get a black screen that says press F1, after I do that I get a black screen with a message that reads, operating system not functioning
Have you take note the error message about the operating system? does it say a corrupted windows file?
With regard to the error message about F1 to continue, i would say that your hard drive is looking for the operating system. There is a possibility that your operating system is corrupted due a virus infected file or a system file was accidentally deleted from your computer or it could be an issue with your hard drive itself.
You may need to check also if your hard drive is detected by computer. You may call your computer manufacturer if your system still under warranty. In case the hard drive need to be replaced.
I suggesst to run a system diagnostics first to check if the hard drive still functioning before you run windows repair using the operating disc you have with your system.
Keep me posted.
Oct 12, 2008 | HP Computers & Internet
My hard drive is corrupted playstation 3
u will need new hard drive installed in it one u got is bad when it says this
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
Disk boot failure
there are multiple reasons for this
1. hard drive failure
solution: replace hard drive reinstall operateing system
2. computer is not set to start from hard drive
solution: enter bios and set computer to start up from hard drive
3. Hard drive not detected or cable loose.
solution: check are the hard drive cables connected well. try disconnecting and then reconnecting.
4. Hard drive file system corrupted and unable to find start up files
solution: you can use the windows xp to enter repair console and try to correct the corruption with chkdsk command if that doesnt work you have to reinstall operateing system
Apr 04, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
