Question about Zebra 105SL Thermal Label Printer
To change Resolution
We are using Zebra 105SL 300 dpi Printer. Now i need the resolution must be : 832 8/mm Full. How & where can i change these settings. Please help me to solve this problem. Regards Gangadharan
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 58 Answers
This link has the user's guide: http://www.intermeccorp.com/pdf/105SLusersguide.pdf
Posted on Jul 29, 2007
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
How can I change the priter resolution in ZM600 for 300 dpi/12 dots per mm;
You would need to replace the Printhead, Platen pulley and Platen drive belt.
There is a kit you can order.
MRP provides IT Parts Product Supplies and Services
Oct 01, 2014 | Zebra ZM600 Printer
Zebra 105sl printer labels print too small
There are 3 different DPI Printheads for Zebra printers if you print a label set up for a 200 DPI Printhead on a printer with a 300 DPI Printhead installed it will be about 66% of the size.
Feb 13, 2014 | Zebra 105SL Thermal Label Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Since changing the print head on a Z4M+ everything is printing small Why?
It`s possible that you install a 300 dpi resolution print head on 200 dpi printer. or check the seting from the printer on (format conver) is "none" - ok, if say 150-300 or 150 to 200, change and save. ps. some printers dont have this seting (s4m)
Feb 07, 2011 | Zebra Z4M Printer
Font height is big in printed barcode. how can I adjust the size of the font?
check if the setting FORMAT CONVERT is with some numbers, please change for NONE.
This seting change the resolution from Printhead 200dpi or 300dpi or 150 dpi or none, none mins, if you have 200dpi printhead, print 200dpi resolution(small fonts). if have 300 dpi, print with 300 dpi resolution, if have 300 dpi(very small fonts) printhead, can print 150dpi(big fonts) if change this setting.
if ok, check the driver or your software.
Dec 05, 2010 | Zebra Z4Mplus Label Printer
105SL is taking template from Label Matrix and stretches it so the data matrix part is unreadable when scanned. How do I make it take an existing template and retain the print size, font and 2D?
Check to make sure you have a 105SL printer driver. Also check to see if you have chosen ZPL for the language as well as the proper resolution (203, 300 and 600 dpi).
Sep 28, 2010 | Zebra 105SL Thermal Label Printer
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Nov 22, 2007 | Zebra Z4Mplus Label Printer
Zebra 105SL Thermal Label Printer Logo
1,777 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Victorman
Victorman
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
