Question about Garden
How to start
Not sure how to start the chainsaw
  • 1 more comment
  • Richard Tracy Oct 29, 2012
    Hard time starting a Jonsered 455 chainsaw
  • Richard Tracy Nov 02, 2012
    To get access to the manual, the site wanted me to signup for a membership which would've cost me $25. Very disappointed in this result!
  • Thomas Perkins
    Thomas Perkins Nov 02, 2012
    Ok,Richard,your chain saw has problems from what I read on line,it says it's hard to start and won't stay running,seen a you tube video and the guy can;t get it started,that ain'y you is it,but to start,push switch to on,pull choke all the way out,lock throttle in and pull string,when it sounds like it wants to start ,push choke in and pull till it starts.
  • Garden Master
  • 14,405 Answers
Click on link.http://www.n8fan.net/item/jonsered-455-chainsaw-manual/
Posted on Oct 31, 2012
My chainsaw wont start.
check the position of the safety lever /clutch as there may be a micro switch that will not allow it to start with the chain engaged
Apr 30, 2015 | Poulan Pro Pp5020av 20-inch 50cc 2 Stroke...
Why won't chainsaw won't start
Not much to go on...
Check to make sure the saw has sufficient fuel. Correct resistor plug, proper compression and spark. If the saw still will not start check flywheel and make sure the key is not sheared.
May 04, 2014 | Husqvarna Garden
Ozito petrol chainsaw will not start and its new
Make sure you have followed the starting instructions, have filled with correct mix of petrol/gas and oil. If it still won't start, take it back to the retailer.
Jan 18, 2014 | Garden
THERE IS NO GAS LEAVING THE CARB AFTER PRIMING THE PUMP OF A PULSON PP4218AVX CHAINSAW. CHANGED THE FUEL LINES AND PUMP. STILL DOESN' T START.
Hi Leo...
Check to make sure you have the fuel lines installed correctly.
Check out the picture below
Please take time to rate me
Bud
Mar 21, 2013 | Garden
Mac 3516 chainsaw won't start
Electronic ignition units work off speed of rotation so make sure yoy are cranking the engine fast enough, make sure the plug is well earthed against the cylinder whilst cranking, make sure the switch is in the on position, if there is still no spark you will have to replace the unit.
Aug 02, 2012 | Garden
Why will homelite 290 chainsaw not start?
Make sure you have blue, snappy spark at the plug (set at 0.020"). If ok, put some fuel mix in the plug hole and try to start--it should pop several times. If pops, then check the fuel system. Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors for theory and troubleshooting. Be sure to check the placement of the gasket in the lower chamber. Hope this helps!
Jun 02, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Looking for a manual for mcculloch pm 484 chainsaw. cannot start the chainsaw.
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Dec 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Cannoy start saw. purchased reconditioned saw this
Make sure you have spark to the plug, make sure the plug is clean and dry,squirt some starting fluid into the plug hole and put the plug back in and try it. If it fires and then quits you probably have a fuel problem
Aug 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Chainsaw won't start
Try getting a new fuel filter. I sounds like its not getting fuel.
Also make sure that you are getting spark.
May 03, 2009 | Garden
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
