Question about Pool & Spa
Raypak 403A, burners will not stay lit for more than a few minutes.
The pilot lights as normal, then the burner will ignite. After the burner ignites, the pilot flame goes very low to the point of going out and then the burner goes out. The pilot will then reignite normally, the burner will reignite, it will run for a few minutes and repeat the cycle. On the other 403A that I have the pilot stays lit continuously when the heater is calling for heat, and the burner is ignited. Would this be a problem with the rectifier or the gas valve?
    Problem Solver:
  • 9 Answers
I'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Posted on Jun 09, 2017
SOURCE: Nexgrill patio heater won't stay lit
I called Nexgrill technical support at 1-800-913-8999. They are sending me a new thermo couple to keep the valve open when ignited - so the patio heater will stay on. I needed to give them the serial number (inside the propane tank door) and fax them a copy of the receipt.
Hope this helps.
Posted on Jul 18, 2008
SOURCE: Pilot Light
i had this trouble with a different fryer. We had lpg instead of natural gas. check youre using the correct gas.
Posted on Oct 20, 2008
  • 10 Answers
SOURCE: My Ruud Furnace wont stay lit
get a new furnace.
Posted on Jan 20, 2009
  • 3 Answers
SOURCE: Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Posted on Aug 14, 2009
  • 990 Answers
SOURCE: Back flare on Raypak pool heater
You will need to pull the burner tray out and clean and blow out the burners. Then you will need to pull the orfaces from the gas manifold and clean each one and blow out the gas line. Then with a mirror you will need to check the fire brick inside the burner box. Then you will need to replace anything that is damaged. Good luck.
Posted on May 15, 2010
Testimonial: "thanks for the insight. I assume that I will have to disconnect the gas line and then reconnect afterward. Appreciate your information."
When I try to use my Thermolaire model SU402E, the pilot lights( and stays lit), but the main burner will NOT ignite.. any suggestions as to what could cause this if the pilot stays lit?
Bad igniter? When you 1st try it the gas valve will give enough gas that you would get the burner lit if the igniter was glowing red. If you're desperate you can light the igniter area w/ an aim n flame, but you definitely want to do that w/ caution and crank up your t-stat so the furnace stays on awhile Cuz you'll have to do it again for heat or buy an igniter($40 or so)
Jan 14, 2015 | Heating & Cooling
Pilot light will not ignite water heater
the pilot light serves to purposes. it is the source of ignition for the main burner and is a safety device that detects wether there is a flame or not. if the pilot light stays on when you stop pressing the pilot light button then you need to turn the knob to the on position to light the main burner. the pilot light is not the on position. if the pilot light goes out when you stop pressing the pilot light button then the thermocouple or flame sensor needs replacing. good luck
Nov 30, 2013 | Raypak Pool & Spa
Pilot won't stay on
Burners don't have anything to do with the problem of pilot not lighting. Is the problem that flame will not 'stay' lit? Or you can't even get a flame to ignite? If former: possible bad pilot generator or bad gas valve. If latter, possible bad gas valve or no fuel to ignite.
Dec 23, 2012 | Hayward H Series Pool & Spa Heater 400k...
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
Jul 27, 2017 | Heating & Cooling
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
