Question about Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups
How do i fix my cuisinart ss-700 from leaking
My cuisinart ss-700 singel serve coffee maker leaks when making a cup of coffee what is causing that
  • 6 Answers
SOURCE: Water leaking from the base of the unit.
Water leaking in the DGB-600 is mainly caused by heated water escaping from its proper path. There is a rubber grommet on the underside of the upper part of the coffeemaker. (It contacts the lid over the filter basket when the front door is closed.) The design in this area is very poor; the grommet does not seat properly in the fixed part of the coffeemaker, and heated water seeps out. Also, the heated water tube that comes up through the cold water reservoir is actually in 2 pieces. One goes inside of the other, but there is no seal. It is a loose enough fit that some steam escapes, condenses on the inside top surface of the coffeemaker, and then finds its way down to add to the leaking. I completely disassembled my coffeemaker (3 of the screws in the upper compartment are hidden under small circular plugs that look like they are part of the plastic surface), and used high temperature automotive RTV sealer to help the rubber grommet seal better, and to seal the 2-piece hot water tube. Works great now! But I must say that I have seen better engineering in childs' toys!
Posted on Aug 12, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
  • 4 Answers
SOURCE: my 12 cup cuisinart coffee pot keeps shutting off
I have the same pot except for the 10 cup model, and it has been doing the same thing. I realized that I have never changed the charcoal filter inside, and I believe that may have been the problem. I removed the filter, ran vinegar through the pot several times as well as cleaned some nasty looking scum out of the water reservoir. I ran 3 pots of water after that. The problem has not recurred so far. I think it may be fixed although time will tell for certain.
Posted on Mar 27, 2010
  • 8 Answers
SOURCE: Cuisinart DC 1150 (10 cup) coffee maker leaks out
I have experienced this same problem. You have to pour the water directly into the holding bay, avoiding the edges. I think water gets stuck around the rim, it just steams over the edge, or drips down the front and back onto the counter. I don't know why, but it happens, so just make sure you pour the water directly into the bay avoiding edges.
Posted on Nov 27, 2010
How do I fix water leak in Cuisinart ss700 coffee maker
if Cuisinart is like my bunn they do not have parts to fix , it is throw away and buy new .
Oct 12, 2015 | Cuisinart SS700 SINGLE SERVE BREWING...
How can i empty the inner tank of a cuisinart ss 700 fr
Hi, Susan
I don't have your model but I'm going to guess that you should remove the external reservoir and run the machine as if you were making tea or coffee.
Mar 22, 2014 | Cuisinart SS-700 5-Cup Coffee Maker
When brewing it makes a loud noise
I have 2 Cuisinart Coffee makers. Both make loud humming noises during the pump cycle. In my units, the water reservoir vibrates when the pump is active. Test by hand pressure on the water reservoir when brewing.
I experimented with adhesive foam pads and they worked well but...they eventually fell off. I often just push the unit against the wall behind it.
Oct 14, 2013 | Cuisinart SS-700 5-Cup Coffee Maker
My cuisinart keurig ss 700 wont turn on
sounds crazy but check switch on side of machine if you have already srry wild shot in the dark (some people dont see extra buttons and switches even though they are good w electronics) took me an hour to realize i had one in plain view and i repair cell phones all day
Nov 28, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Ss-700 keeps flashin Not Ready
I had the flashing not ready problem with my SS-700 Cuisinart as well. I pressed and held the rinse and Hot Water buttons at the same time for about 10 seconds while the Not Ready was flashing. After 10 sec or so the display went off completely. I then powered up with the power switch on the side and the coffee maker came and is working fine so far.
May 13, 2012 | Cuisinart SS-700 5-Cup Coffee Maker
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
Nov 22, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart ss-700 open head message stays on...
I have the same problem and wonder how to fix it
Feb 03, 2011 | Cuisinart SS-700 5-Cup Coffee Maker
Cuisinart Keurig B50 Single Cup Coffee Maker + 12 K Cups Logo
146 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
