Question about Canon PowerShot SD600 Digital Camera
Center of picture is soft (out of focus)
I have reset my camera but still get images that are in focus on the outer edges with the center soft and grainy. i have reset the camera with still no change? i have a powershot SD600.
  • paulc846 Jan 11, 2009
    thanks so much for your help. it was just a smudge!
  • Anonymous Apr 26, 2009
    how much does it cost to repair/replace the sensor?
    Novelist:
  • 121 Answers
Paulc846,
There might just be a smudge or fingerprint on the lens, that's enough to cause that to happen to the center of an image. Get some lens cloth on a q-tip and try to gently wipe it clean. If the image is really grainy and the camera has recently been dropped the sensor is damaged. Let's hope for the smudge.
randy320sgi
Posted on Jan 09, 2009
  • Randy Wheatley
    Randy Wheatley Jan 14, 2009
    You are welcome, I'm glad that it wasn't worse.
Remove purple haze around edges
The set needs to be focussed and reconverged. The red and blue images combined make a magenta/purple image. Adding green makes it white. Depending on the type of TV, if it's a CRT projection TV then there's an electronic focus control for each of the three tubes as well as the mechanical adjustment of the optical lenses. Given the description, then I'd have a look at the electronic focus first. A sudden shift in focus suggests that something in that circuit has given out. This would cause the red and blue images to go soft enough to create a halo around objects on screen.
Sep 12, 2014 | Televison & Video
Tip
How to improve picture quality of Digital Camera
Slow down the shutter speed of your digital camera. Whenever you must take a photo in a low light environment decrease your shutter speed. It is virtually impossible to take a blurry digital photo with a an extremely slow shutter speed. Even if your digital camera has an automatic or semi-automatic mode, slowing down the shutter speed will still produce a better digital photo. <br /> Wait until your digital camera is completely focused. Most digital cameras will notify you that they are focus ready by a blinking light, on screen indicator or a noise. Confirm that your digital camera has locked onto your desired target before pressing the shutter release button. Some digital cameras may have trouble focusing on subjects easily. If this happens use an auto focus mode to produce a better digital photo. <br /> Prevent your digital camera from shaking. Shaky hands or sudden movement will definitely produce a blurry digital photo. When holding your digital camera, make sure the viewfinder is firmly pressed against your face before snapping a digital photo. If you do not have image stabilization on your digital camera, then think about investing in a tripod. This will allow you to steady your digital camera for the perfect shot. <br /> Make sure the digital image is definitely a blurry one and not just a soft image. On many occasions soft images are mistaken for blurry ones. Soft images occur often with digital cameras. When printing these images, the softness rarely shows through. You will be able to easily edit these photos by sharpening the details for a better printing experience. <br /> Take your time. Instead of rushing to take a digital photo, set aside enough time to shoot your image. Hurrying up will not produce an excellent digital photo. You don't need to be overwhelmingly slow when taking the photo, but try your best not to take a hasty one.
on Dec 31, 2010 | Cameras
Camera
Step 1:
The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam.
Feb 07, 2013 | Craig Computers & Internet
Camera out of focus
A webcam is first and foremost a camera that uses a lens to gather light reflected by an object. There are a number of reasons why the image captured by the webcam can be blurry, all of which can be remedied. Supplies from a photography store or hobby shop, along with items that most people already have in their homes, are needed. The webcam does not need to be disassembled in any way in order to obtain a sharp and clear image.
Launch the webcam's video program by selecting it from the "Start," and the "All Applications" menu. Aim the webcam towards you so that you can see the blurry image presented in the program's video window. Rotate the knurled focus ring that surrounds the lens at the front of the webcam until the image is sharp; if there is no focus ring, position the webcam closer or farther from you until the video image is sharp. Blow off the lens at the front of the webcam with compressed air. Moisten the end of a cotton swab in photo lens cleaning solution. Wipe the lens with the moistened end of the swab, beginning at the center and rotating in a circle until you reach the outer edge. Wipe the lens dry with a lens tissue in the same manner as was just done, to remove the contaminants that caused the blurry image. Launch the webcam video program that is on the hard drive. Select the "Advanced" or "Options" tab at the top of the program's main window -- depending on how the program is set up to bring up a settings window. Reset the "Sharpness" control to 65 percent of the total possible, using a slider control or entering "65" in a text field. Click the "Apply" button at the bottom of the window, followed by the "OK" button to sharpen the image transmitted by the webcam. Hope this helps.
Jan 25, 2013 | Computers & Internet
I am having a problem with my new Pentax DA 50-135mm 2.8 lens not focusing
Hi Ally,
It sounds like you may have commanded the camera to use one of the other 10 focus points in the viewfinder. There are 11, total with one in the very center, and the rest around it. It looks like this:
Page 130 of the manual begins a discussion of Auto Focus. Page 133 details how to change the focus point. If you like to center the subject in your veiw finder & pictures, you should select the center focus point if it is set to one of the others. You may still have dark or soft pictures if the shutter needs to stay open too long. You can reduce the exposure time by bumping up the ISO to a value of 400 or 800 or more - as limited by you liking. The higher your ISO goes, the less time required - but the more grainy the image is.
Jan 28, 2012 | Pentax SMCP-DA 50-135mm f/2.8 Lens for
I'm taking exterior shots of a building using the auto mode. The roof comes out wavy. Have an appointment shortly to take more pics. Why is this happening? (I miss my old SLR ...)
Cameras are subject to some unusual conditions due to lenses being round and the image you take being square. They work better the closer you are to the center of the lens. Normally you don't see this, but when you take a picture of something long and straight and it's near the edge of your picture, it can come up wavy or crooked.
You can recompose to avoid long straight things near the edge, or you can take several pictures and stitch them together in Photoshop. This will let you get the roofline more near the center of several pictures, and then after you stitch you can crop to make the photo the way you want.
You're dead on about the SLR, though. SLR's have bigger and better lenses, and on digital SLR's, the sensors are much bigger. This gives them huge advantages in how they focus light, and overall it makes the near edge lens issues less noticable.
Sep 03, 2009 | Canon PowerShot SX10 IS Digital Camera
Hi, I have a issue with the quality of the pictures I've taken recently on my Z2, the pictures a blurry around the edges. The centre of the photo is sharp. Do you have any suggestions please of what to do,...
This is due to settings change
Please switch the focus mode to multi point focus or any other
current setting will be center focus or spot focus that is why only the center is focused and the rest is blurry
Please refer to your fuji manual for instructions on how to change the focus mode
Thanx and i hope this solves your problem
Please dont forget to rate this information
Jul 17, 2009 | Fuji FinePix Z2 Digital Camera
I have a Sony DSC-F88 5.1MP camera... When you switch it on to any of the program modes - image dispalyed on LCD and photographed is distorted. Image is skewed with the edges of the image flaring with...
Your DSC-F88 has problem with CCD Imager and needs to be replaced. Good news is Sony will replace it free of cost. Click Sony Official website to get further instructions. Hope this info will helpful for you.
Aug 12, 2008 | Cameras
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Powershot Focus Problem
I have exactly the same problem and the image looks exactly like what you showed. I didn't abuse either. Currently, I'm talking to Canon Support and they have a known issue on S60 and will fix it for free,provided this issue is same as the experienced by us. Will keep you posted.
Apr 09, 2007 | Canon PowerShot S50 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
91 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
