Question about Disney DTD1363-CAR 13" TV/DVD
Turns Off After 30 Min - Need Power Supply Component Source
Using component cooler I've isolated the issue to what looks to be a rectangular hybrid component with an epoxy top in the power supply section.  The part numbers are as follows:
Top Row - U4 Middle Row - M273BHL Bottom Row - 9RM
The component has three prongs soldered to the motherboard.  TV is Model DTD1363-CAR with mfg date of May 2006.  I believe the manufacturer is Memcorp, and I know that fox-international.com (815-741-5859) provides support for Disney electronics, but so far Fox Int'l hasn't been helpful.
I'd appreciate any help from the group in finding this component or a substitute.  Thanks in advance.
  • adamjoyday Feb 22, 2009
    I have the same problem, however, I was cooling the coil right beside it with a pn of 36-l1folo-xx0, now I wonder if I was sloppy when I was cooling the component and was cooling the one you isolated :( I was sure it was the coil, however, I will have to get another can I guess.
5 Suggested Answers
SOURCE: Disney DTD1363-car, Need part # of transistor
The tv keep shuting off an the dvd door won't open. I have model # DTD1363-CAR
Is there any recall on the tv
Posted on May 21, 2008
SOURCE: Region Settings
Turn Player On
Open The Disk Tray (Leave Open)
On Remote Control Press Stop
On Remote Control Press 1.3.6.9 and 0 (Zero)
Close Disk Tray
Power Off
or
Turn Player On
On Remote Control Press Clear
Close Disk Tray
Power Off
Posted on Jul 07, 2008
SOURCE: car tv dvd turns off
solder the flyback to the main pcb, one of the pins has a cold solder joint.
Posted on Sep 18, 2008
  • 12 Answers
SOURCE: Disney DTD1363-CAR 13" TV/DVD Combo Problem
TV/AV/DVD button behind door far left
Posted on Nov 05, 2008
  • 6 Answers
SOURCE: Disney Cars TV-Model DTD1363-CAR 13" TV/DVD
I have 1 , exact same problem. I took it to a local repair shop and it turned out to be loose connections on the circuit board. It was explained to me that as the problem became more frequent it was the connections getting worse. It cost about $100 (give or take).
Posted on Nov 15, 2008
Just bought a used 27"
1. Turn on the TV or component.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
Aug 18, 2011 | ESA EF427E TV
Hi! I need the code/s to program a Konka TV using RCA Universal Remote Controller model RCR311S. Tnx...
I could not find the code listed for the Konka brand, but that does not mean that you cannot use the remote. Here are some real easy instructions on how to perform a code search with that remote for that television. I had to do this for my sister just a couple of days ago.
I hope that you have found the information that I have provided helpful as that is my goal.
Auto Code Search and Entry If your component's brand is not listed in the code tables, or if you have tried all of the codes for your brand and the remote does not operate your component, try the Auto Code Search method below. The remote will cycle through all of the codes, in the event that your code is listed under another brand. The Auto Code Search method may take a long time because the remote searches through all of the codes in its memory for the code that operates your component. Therefore, if your brand appears in the code lists you should try first the Direct Code Entry method described above.
Step 1: Manually turn on the device you want the remote to control (TV, VCR, DVD, cable box, etc.).
Step 2: Press and hold the device button (TV, VCR, DVD, etc.) you wish to program. The illuminated ON/OFF key turns on and remains on.
Step 3: While holding the component button down, press and hold the ON/OFF key. The illuminated ON/OFF key turns off.
Step 4: After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 5: Release both keys. The illuminated ON/OFF key remains on.
Step 6: Press and release the PLAY button, then wait 5 seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every 5 seconds until your component turns off. Each time you press the PLAY key, the illuminated ON/OFF key blinks and a block of ten codes are sent to your component. This process continues until all of the codes have been searched. If your device has not turned off after all codes have been searched, the illuminated ON/OFF key blinks 4 times and turns off. The Auto Code Search Entry method is exited.
Step 7: When your equipment turns off, you know'll that the correct code is in the last block of 10 codes sent. Press and release the REVERSE key, Wait 2 seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE button every 2 seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON/OFF key blinks.
Note: If you accidentally press the REVERSE button after your device responds, press and release the FORWARD key. Wait 2 seconds to see if your component turns off again.
Step 8: Once your component turns on, you have found the correct code. You must save the new code by pressing and releasing the STOP key. The illuminated ON/OFF key turns off.
Important: You must press the STOP key to save the code or the correct code will not be stored!
Jan 15, 2011 | Televison & Video
We have a panasonic ct-36d31e that has developed a degaussing problem now. Rainbow colors - magnets haven't helped neither has power drill placed near the screen. Is there a degauss button on this model...
Hi Tracy,
Unfortunately magnets etc will most likely do all but improve the problem. When a T.V set is turned on it automatically degausses (demagnetises) the tube. However, if the screen does not degauss, its most likely a small electronic component in the degaussing circuit which has burnt out. This component is usually black in color, is rectangular and about the size of of the T.V. screen displayed alongside your question. Its inexpensive to replace(less than $5) and can be found at most electronic component stores.
Please let me know if I can be of any further assistance.
Best wishes,
Graemevm
Dec 23, 2009 | Panasonic CT-36D31 36" TV
I HAVE AN SANSUI DTV2798 TV TURNS OFF AFTER ABOUT ONE MIN
the protection circuit is being engaged This is often due to a faulty component that heats up quicly and sets the sensor off. It turns off to prevent fire, so maybe don;t turn it on and get it fixed.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Televison & Video
Dead Set after power surge
Check the power supply transformer primary driver transistor and the associated components (some diodes and capacitors, resistors, an optocoupler maybe) and the rectifier diodes (or a bridge) and capacitors at the transformer secondary, what you are looking for is a short circuit, however, the short may as well be in another section of the circuit board (a shorted component may sometimes have signs of damage caused by heat, but this is not a rule).
Hope you can find out what it is...
regards
Triarcuate
Oct 01, 2009 | Televison & Video
Picture dies after 30 min
That is the power supply defective or the main board is overheating.
The technician will start the Set with cover open and point a fan as big as possible toward the main board, if the TV stays on longer or does not turn off at all then it was an overheating problem on main board. Replace cooling system, or even better add an additional cooling fan to the heath sink.
If this was not overheating test inverter and power board.
Note this model suffers from overheating related problems, but as you pointed out, a faulty power board, or a faulty inverter board can cause the same kind of shutdown.
Apr 16, 2009 | Samsung TXR3079 TV
Blows 4 amp fuse inside tv
the poer supply faulty. Isolate Horizontal output stage from the power supply and connect dummy load (like normal bulb same wattage as TV ) and test. before that pls check all component in power supply and replace and burnt parts spacialy diodes caps and power regulater ic as well
Jan 15, 2009 | Televison & Video
Need codes to control symphonic 27" tv using rca universal remote control type rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Tips
  • Turn on TV
  • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
  • Press the PLAY button every 5 seconds until the device turns off
  • Press the REVERSE button every 2 seconds until the device turns on
  • Press the STOP button to lock in the code...the remote should work now.
  • Important to press reverse button every 2 seconds, not just once.
Good Luck!!
Aug 18, 2008 | Televison & Video
Philips tv chassis L9.2A
The flashing LED is an indication code of a board problem. If the TV is shutting down after a very short period of time, it is an indication the something is heating up. To isolate the problem, you will need to purchase some freeze spray ( component cooler ) at your local electronic shop. turn the tv on and spray an area ( usall about 1/4 of the board at a time ) and try to isolate the bad part ( component ). By repeating this process after a bit of time, you should find the part thats bad when you cool the part and the set stays on until the part heats up again. Then simply replace the part and your good to go. Always use precautions when working inside a tv as the picture tube can have as much as 35,000 volts on it ( can cause bodly harm or death ). DON'T COME IN CONTACT WITH THE WIRE OR GET CLOSE.
Good luck and I hope this has helped
Ed
NC Electronic
Mills, Wyoming
Jan 24, 2008 | Televison & Video
Samsung PCK5315RX TV turns off
you tv problem is intermittent have a tech resolder you tv circuit.also have him check the power supply you could be having problem with the component there.probably the regulator diode or cap.good luck
Aug 01, 2007 | Samsung PCK5315RX TV
Disney DTD1363-CAR 13" TV/DVD Logo
69 people viewed this question
Top Disney Televison & Video Experts
sonic boom...
sonic boom...
Iron
Iron
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
