Question about Cell Phones
This product is made by Karuna Borneo. It is a power charger, model KBM300. It charges my iPhone when low. It is a Li-Polymer battery, 3.7 volts/3000 mAh. The video shows it plugged in to the wall
    Problem Solver:
  • 10 Answers
Did you use it before you charged it the first time ?? If so it may never take a full charge because ive been told they are set at what ever the first charge is set at and they dont come fully charged.
Posted on Oct 29, 2012
  • 490 Answers
SOURCE: charging problem
problem is with the hardware of the handset so visit nearest nokia care . or visit http://nokia.com to get info about ur handset problem
Posted on Oct 10, 2007
SOURCE: Battery will not charge
looks like the solution is pay a bloody fortune to lg to check if they can fix it or do what im doing and buying a desk top charger i have all ready bought a second battery so that way one can be in the phone while the other one is charging .they only cost about 10 dollars ill let you know how that goes
Posted on May 26, 2009
VinayT
  • 1884 Answers
SOURCE: SAMSUNG ALIAS WILL ONLY POWER ON IF PLUGGED IN TO THE CHARGER
battery may show fully charged while charging, but it can noot hold the charge. So you need a new battery. If under warranty ask Verizon for replacement.
Posted on Aug 05, 2009
SOURCE: my samsung gravity 3 won'ty charge in car
This problem cannot be fixed. You'd have to return your Gravity 3 and exchange it for another model. It's a known problem with Samsung and should acknowledge it and recall this product (or fix it with a software update free of charge). I spent a whole day at different T-Mobile stores and finally a rep showed me the technical bulletin on it and exchanged the phone.
Posted on Sep 14, 2010
SOURCE: I have a new Sony
You probably have multiple apps running and don't know it!!!!! My friend suggested this to me and so far it has helped.... I downloaded Advanced Task Killer and I "kill" everything that I'm not using. The only thing that bothers me and I wish I could figure it out..... if I check this task killer once per hour, there are so many apps that are open that I didn't even use. I'm not sure why this is happening and havent had a chance to figure it out. But I hope this helps, I can be long winded for nothing so.....there's my two cents, hope it works out for you =)
Posted on Oct 12, 2010
My hesh 2 will not charge the light does not come on when trying to charge
A possible answer is the battery has failed or has become too low in voltage.
Many equipment these days have the new Li-ion or Li-polymer batteries which hold a high charge and are light weight but require a specific charge up routine as they can get "unhappy".
The charger circuit determines when it has reached max charge and stops, but also it will sense if a battery is to low or under a point which it can recharge it.
This is because the charger would have to exceed its maximum safe current so stops, this is a problem because many imported equipment now will have no OFF switch only a standby situation, this causes a very low power drain which can over time deplete a battery below this point.
The only other obvious item would be its charger unit is working which needs to be checked, I would assume like most things its a 5v plug in item with a mini/micro usb plug socket setup you can get testers to show if they are giving out a voltage or your nearest electronic shop.
Though most answers are because of the battery condition than any other so it may need a service.
Hope this helps
Mar 08, 2017 | The Audio Players & Recorders
What is part number zilog3055 on circuit board of DW9107 battery charger?
this 3055 ?
The zilog3055 device is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2-series, 3-series, and 4-series cell Li-Ion and Li-Polymer battery packs.
Using its integrated high-performance analog peripherals, the bq3055 device measures and maintains an accurate record of available capacity, voltage,
Nov 04, 2015 | Drills
How to change the battery in my Anycom HCC-250
A rechargable Li-Polymer battery should be included with a charger for it when you bought it.
Note:
It is recommended to charge your Car-Kit when it is not in use.
Please note that "inserting" charger will cause a device reset. However, when the Car-Kit is in charging (the charger has been inserted), the Car-Kit is in normal
operation
Oct 16, 2015 | Anycom Radio Communications
Battery won't charge up
One or more of the cells in the battery may have died while it wasn't being used. LI-Po batteries are memory resistant but they can still develop one if they're left fully discharged too long or at a half charge too long. They require full charge\discharge cycles to keep them from developing a memory.
Feb 13, 2012 | ESKY 001336 20C 11.1V 800mAh Lithium...
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
Mp3player 2gb smp2012
most of the time when your plugged into the pc it will charge see if this is true for your player if so leave it on the the pc for a few hours also drain the battery fully then charge for a few hours
Sep 15, 2009 | RCA M4204 MP3 Player
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Dell Laptop Battery Charer
Or it could be a broken/damaged power pin that is causing the problem. Every time you tug or pull on the pin it causes damage...eventually it doesn't work at all. When you get it fixed you need to invest in a CRD (Cable Retention Device) like shown here. . .
Jan 25, 2008 | Dell Inspiron E1505 Notebook
Cell Phones Logo
74 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
