Question about HP Computers & Internet
Problem regarding laptop screen.
My laptop screen has been compressed in height and stretched in length. I cannot see the rightmost part of the screen but can access it. The lower part of screen displays 2-3 mm image of the upper part of screen. It seems like two identical photograph one below the other and the former only a little visible. Please help me. it happened when laptop was not responding and I tried to shut it down forcefully. I pressed the start button for long to switch it off. When I restarted it, the screen was disturbed. I've tried restore and screen resolution thing but it didn't work.
  • HP Master
  • 7,627 Answers
Pehaps the monitor is going or the drivers need to be replace? How old is the laptop, has there been any damage done, drop, jared? I have aHP DV 9320 and I knocked it over on a carpeted floor and the screen went out a ribbon cable jared loose, I open the monitor and fixed it. It could be as simple as adjusting your desktop to "full, Stretch,etc." in Desktop Background settings.
Posted on Oct 29, 2012
  • Manish Pathak Oct 30, 2012
    It was not damaged or dropped. I just switched it off forcefully, The next time i switched it on, i found the problem.
  • max carson
    max carson Oct 30, 2012
    I just switched it off forcefully, meaning you held down the on/off button until it went off?Anyway, can you load your desk top desplay settings? if so look for the desktop background settings, have you changed your desktop theme as of late? Their are settings to change the desktop displat: FILL, STRETCH, etc.Have you tried the settings?
3 Suggested Answers
rubydu
  • 102 Answers
SOURCE: Problem with booting-up on HP Pavilion dv9334us laptop
1.there is problem in screen fl inverter replace it screen will on
2.format and reload the windows
Posted on Jul 17, 2009
  • 615 Answers
SOURCE: hp dv9700 doesn not start
try safemode if not check F2 for mem.
Posted on Sep 08, 2009
How to build height without medicines suggest only exercise
1. VERTICAL HANGING:
This is a simple but an extremely effective stretching exercise which you can do at your home. All you need to have is a solid bar strong enough to hold an individual, fixed at least 7 feet above the ground such that the distance between your feet and the floor is atleast 4-6 inches. Hold your arms neither closer nor wider and start hanging. Hold as long as you can, and as you begin to tire, slowly swing back and forth and try to touch the ground with your feet. This will flex your spine and elongate it, so that you can add few inches to your height
Make sure that you flex your spine while stretching, and not merely twisting your wrists
Perform the Workout 3 times a week for optimal results
2. COBRA STRETCH:
This is basically a Yoga exercise intended to stretch your spine and make it supple and flexible, so that the cartilage between your vertebrae grows thereby increasing your vertical height
Lie on the floor face down with palms on the floor under your shoulders. Begin to arch your spine up leading with your chin. Arch as far back as possible. Do 3-4 repetitions with each repetition lasting between 5-30 seconds
3. PILATES ROLL OVER:
This is an excellent workout to stretch your spine and lengthen your upper body. Apart from your spine, it also stretches and lenghthens the vertebrae of your neck.
Lie on your back with your arms along your sides, palms down. With your legs together, extend them straight up toward the ceiling and bend them backwards so that they touch the floor. It may not be possible to touch the floor at first, but you can do this by practice. The more your stretch, the more your spine lenghthens
4. FORWARD SPINE STRETCH:
Sit up tall on a mat. Your legs are extended about shoulder width apart, and your feet are flexed. Reach the top of your head but let your shoulders stay relaxed. Inhale and extend your arms out in front of you and slowly bend forward and try to touch the tips of your toes. If you are able to touch your toetips, stretch even forward so that your spine is flexed to the maximum extent.
Do 3-4 repetitions and hold each stretch for 10-15 seconds
5. ANKLE WEIGHTS: This exercise is solely intended to increase the length of your lower body, by stretching the cartilate between your knees. Prolonged stretching will elongate the cartilage and increase its mass, which in turn will increase the length your lower body
Sit on a high chair and use a Ankle weight fastener to add weights to your ankle. Start with small weights initially and gradually increase as you go on. Allow your legs to stretch down with the pressure of the weights. Once completed, remove the weights and relax your legs by kicking your legs gently for 5-10 times, and then vigorously for 5-10 times. This will flex your knee cartilate to enable it to grow in length
Apr 13, 2012 | Health & Beauty
Clutch cable adjusters
Bowden cables like your clutch cable work on the law of the lever. Think of lifting up a heavy weight hanging on a rope using a lever balanced on a fulcrum. The rope is in tension and the fulcrum is in compression. To adjust the point of lift you could either vary the length of the rope or adjust the height of the fulcrum. The outer sleeve of your clutch cable is made out of plastic-coated steel, square-section wire and is resistant to compression forces along its length. This outer sleeve works as your fulcrum and, because it is flexible, lets you put it where it is needed - at the end of your handlebar. The cable inner is like the rope in the lever example and resists only stretching forces. It is threaded down through that snaking fulcrum back to where control movement is needed. The cable adjusters let you fine tune the length of the fulcrum, and therefore the lift range of the inner cable.,,,
Nov 10, 2008 | 2005 Enfield Bullet 500
Nov 10, 2008 | 2002 Cannondale C 440
Nov 10, 2008 | 2008 Buell XB12XT
Nov 10, 2008 | 2000 Buell S3T
Nov 10, 2008 | 2006 Bimota Tesi 2D
Nov 10, 2008 | 2006 Bimota DB5 Mille
Nov 10, 2008 | 2008 Beta RR 450
Nov 10, 2008 | 2008 Beta Alp 125
Nov 10, 2008 | 2006 Benelli TnT Titanium
Computers & Internet Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
