Question about Garrity Replacement Bulb
Trying to replace the light in my garrity AA battery flashlight.
I unscrewed the top and the light appears to be sitting in a mechanism that I tried turning both ways but it does not move. I tried to pull on the bulb but was not able to get it out. I am not sure what is holding it in place. I then have to find out where to get the replacement bulb. All I can tell is the flashlight is blue metal with a black rubber grip handle with finger grooves on the bottom. I purchased it years ago. The on and off switch is at the bottom end of the flashlight. Any and all assistance is greatly appreciated. Perry
  • 17 Answers
SOURCE: I have a Garrity LED tuflight flashlight with 3
you should load the spring/metal piece in first with the spring facing out. then the batteries.
Posted on Sep 08, 2009
  • 973 Answers
SOURCE: replacement 6v charger for Garrity spotlight
Contact Garrity at http://www.garritylites.com/contactus.html
Posted on May 25, 2010
  • 28 Answers
SOURCE: How do you change the AA battery's for a Garrity
If its the one I have ... A battery may have failed and leaked causing it and the battery unit to become stuck. I pulled off the top of mine and pulled out the LED assembly and banged it on the bench a few times and it popped out and I cleaned it up with some baking soda and water.
Posted on Aug 31, 2010
  • 3247 Answers
SOURCE: I have a Garrity Industries
The notched end of the unit is the lid of the battery cover. It might be cross-threaded.
Immerse that end in hot water and then twist holding with a dry towel.
Hopefully that should open it.
Posted on Sep 02, 2010
Gophering
  • 187 Answers
SOURCE: I have a garrity G-Tech
NEGATIVE ENDS ALWAYS GOES TOWARD THE SPRING!
Posted on Aug 25, 2011
Not sure which bit to unscrew when trying change battery in onyx50
The flashlight uses 1 AA battery. My guess, you should only have to unscrew the end cap. If you finds it very hard to unscrew the end cap off, it could be from the battery has explode and swollen. MAYBE - I see this happen in my daughters MAG flashlight. DO not keep your flashlight in the car with the batteries installed. The amount of heat in the cars can ruin the batteries in the flashlight.
Apr 06, 2016 | Gerber 22-80144 Onyx 50 Flashlight
How do I access the battery compartment on model 06443
To change the batteries in your flashlight, unscrew and remove the base tailcap, as the end that doesn't have the light. Remove the battery holder, replace batteries and then replace the battery holder in the same way that it was taken out (spring first).
http://ledmuseum.candlepower.us/fourth/gled.htm
Feb 21, 2015 | Garrity Camping, Backpacking & Hiking
Battery for spot liteS800G
Most likely has been charged as many times as possible. Time to replace the battery.
Jul 15, 2014 | Garrity Camping, Backpacking & Hiking
How to replace bulb in garrity stainless steel pen light
I have a Garrity stainless steel flashlight that is approximately 6 inches long. It uses two AA batteries. The light is turned on and off using a push button on the back (push on, push off). The head-end turns to "focus" the light. The lamp, itself, is incandescent. It is 9/16-inch long, including the two 1/4-inch wire leads. The flashlight was purchased 11 years ago, and the lamp just burned out. When I called Garrity, they said they no longer had replacement parts for these flashlights. Which is strange, given you can use Part 2A001 Mineature Bulb G1.27 Base bulbs available from Bulb Town in Jacksonville, FL, as replacements. They work like a champ! If you have any questions, ask to speak to Melinda.
Apr 13, 2013 | Garrity Replacement Bulb
How do you change batteries stanley 3 in 1 tripod led flashlight
The unit is 3 individual flash lights. Pull one of the flashlights by the head (the light part) it will come out easily once you know what you are doing. The other two may be pulled out in the same manner. The bottom will then unscrew where you will be able to replace the AA batteries. Each flashlight will then go back into place very easily. Hint...test each individual flashlight before putting back together to make sure you have your batteries in the proper place and that they are useable batteries.
Dec 08, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
How do you change the AA battery's for a Garrity Aluminum Flashlight?
Sep 19, 2009 | Garrity Led Rch Flashlight
Don't know how to replace AA batteries in Maglite AA.
they either unscrew from the back end or they unscrew from around the thick light end , then just pop in some new batteries making sure that they are pointed in the same direction
Jun 02, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Garrity Replacement Bulb Logo
94 people viewed this question
Top Garrity Camping, Backpacking & Hiking Experts
Tom Queen
Tom Queen
aron5566
aron5566
tjcwriter
tjcwriter
Are you a Garrity Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
