Question about Dell Dimension E310 PC Desktop
Floppy diskette seek failure
I have a Dell Dimension E310 and when I boot the unit is gives me a black and white screen stating "Floppy Diskette Seek Failure". When I try to go into the set up screen it just reboots. What could this be? I have a Dell Dimension E 310
and mine says floppy diskette seek faliure.
can you tell me how to get this off everything works fine except for this problem.
  • angeleyes4u5 Jan 05, 2009
    i have gone into F2 but i dont know what to after i am there i try to get this F! floppy diskette off but nothing happens
  • Bill Speer
    Bill Speer May 11, 2010
    Are you using the F2 key when it's booting to get into the BIOS setup screen?
  • 123 Answers
Try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Posted on Jan 05, 2009
  • shibukpza
    shibukpza Mar 19, 2013
    NOTHING HAPPENED SAME PROBLEM
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
Dell optiplex 745 Floppy Diskette Seek Failure
how to solution. Dell optiplex 745 Floppy Diskette Seek Failure
Jan 20, 2012 | Dell Computers & Internet
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
A used dell computer, hooked it up and black screen comes up and it says diskette 1 seek failure
Below is a list of possible causes.
Faulty or improperly inserted diskette, incorrect configuration settings in System Setup program(You might be set to boot from the floppy drive. You want to be set to boot from the hard drive), loose diskette/tape drive interface cable, or loose power cable.
If possible please rate this solution.
Aug 26, 2010 | Dell Dimension 8250 PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Floppy Diskette Seek Failure on boot up
Hello there:
This is a setting in the bios , so what you are going to have to do
is boot into bios and under the boot section and check to see if the floppy drive is a option that is part of the boot sequense if it is change it so that is not part of the boot sequense than go under the periphial section and check to see if it is showing up there as a removable device if so change it or disable it all together since you do not have a floppy drive ok
and this should take care of he problem
I hope that this is very helpful for you
Best regards Michael
Dec 06, 2009 | Dell Dimension 4600 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
F1 floopy diskette faliure seek faliure
Make sure it is not disabled in the boot order, there is also an option for the drive itself (Diskette Drive) that must be disabled
Jan 05, 2009 | Dell Dimension E310 PC Desktop
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Jan 14, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension E310 PC Desktop Logo
628 people viewed this question
Alun Cox
