Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Fills with water then stops - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 7,627 Answers
Control Switch?
Posted on Oct 29, 2012
My ge top load washer will not stop filling up with water
The water level switch shuts the water off when it gets to the desired amount. Also change the water level to low and see if it stops at different level.
Jan 06, 2015 | GE Washing Machines
Water does not stop filling with water
The possibility is faulty water inlet valve.The valve lets the water to enter the machine.But if this valve is got weak/faulty then it will not stop the water from entering.If the water fill vale is checked ok then other possibility is faulty water fill valve switch.The switch detects the required water in the washing machine and shuts the fill valve off,but if the switch is faulty then it will not shut the water fill valve off and this will not stop the water from filling and this overfills the water.So most cases the water fill valve is faulty and it has to be replaced.But if the fill valve is checked ok then other possibility is faulty water fill valve switch. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. To get required parts ,you can get it from www.repairclinic.com . Keep updated if any more queries.Thanks.
Oct 14, 2010 | Kenmore 24032\24036 Top Load Washer
Water fill doesn't stop filling cold water
check washer pressure vale and the tube connect from the tub to pressure vale most of the time the mouse bite the hose some where in the panel con trol of the washer good luck
Mar 03, 2010 | Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Wahser does not stop filling water
replace the water inlet valve
May 03, 2009 | Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
If you turn power off to machine (or unplug) and washer continues to fill, you need to replace the water inlet valve. (the part the hoses connect to) If cutting power stops the water fill, you have a problem with the water level switch or the tubing leading to it.
Oct 28, 2008 | Whirlpool Washing Machines
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
