Question about Symbol LS1902T-1000 Handheld Laser Barcode Scanner
Symbol ls1902t-1000 scans extra characters when scanning a barcode
When I scan an item with a barcode it adds "}W" before the barcode.
  • 4 Answers
Download the quick start guide from support.symbol.com and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Posted on Dec 15, 2012
  • 5 Answers
SOURCE: Symbol handheld scanner problems
scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Posted on Aug 15, 2008
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
  • 31 Answers
SOURCE: Program Symbol LS2208 scanner
Hello this requires advanced data formatting which you will have to scan some bar codes to program it. If you give me your email I can send the codes to you.
Posted on Jun 30, 2009
  • 74 Answers
SOURCE: Symbol LS2208
From the LS2208 Product Reference Guide you should print and scan the following barcodes:
Begin New Rule Adobe page 232 of 342
Send all data that remains Adobe page 246 of 342
Send tab key Adobe page 286 of 342
Send 1 Adobe page 270 of 342
Save Rule Adobe page 232 of 342
That should do it. If you find the scanner sends the 1 too quickly after the tab key you may want to scan Send Pause in between the Send tab key and Send 1 statements.
Posted on Mar 16, 2010
Testimonial: "International Rescue A bit like the (UK) 1960s TV series ?Thunderbirds? someone somewhere in the world has come to my rescue!! Briliant job--- who ever you are where ever you live THANKS "
  • 34 Answers
SOURCE: Need to add prefix ~ and suffix / for ls2208. I
Have a read through this document.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
look at 13-4
have you tried scanneing the enter barcode after 6 ?
Posted on Oct 19, 2010
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
Add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
Jan 28, 2011 | Symbol LS1902T Handheld
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Aug 11, 2008 | Symbol LS2208 Handheld
Need instructions
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf
Jan 14, 2008 | Symbol LS1902T Handheld
Symbol LS1902T-1000 Handheld Laser Barcode Scanner Logo
490 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
