Question about RTO Ho Herpa Freightliner Truck Tractor
Freightliner Mid 128 351 04 what is the code for?
Detroit 60 series
3 Suggested Answers
  • 19 Answers
SOURCE: I own a detroit diesel 60 series.will not
srs trs sensors they r what times the motor oone is behind ur air compessor the other is below the compressor
Posted on Aug 15, 2010
  • 28 Answers
Ck fuse for ecm if ck engin and stop engin won t light at start up it s gonna give you a clue about ecm power
Posted on Dec 15, 2011
Where to find wiring schematics for a 2000 Freightliner Classic XL with a 60 series Detroit
the only sure place is a service dealer
ask they to print out a copy for you
Sep 10, 2017 | Cars & Trucks
2014 freightliner cascadia, dd13 showing an active code mil light Diag, says ecu 01 , what can that be
the code dd13 for a detroit series 60 refers to coolant level sensor ---input voltage low
should be in the radiator top tank and energizers when the coolant level in the cooling system falls below a set point in the radiator
contact a service dealer for a diagnosis and information as to the fix.
Sep 05, 2015 | Cars & Trucks
What does codes 54 and 55 mean on my 2001 freightliner columbia 60 series detroit
code 54 (DDC#( flashed ) refers to vehicle speed sensor fault
code 55 (DDC# flashed)refers to other ECU fault ( this fault is logged in conjunction with another fault to indicate missing information from another ECU. it also refers to J1939 data link fault
May 19, 2015 | Cars & Trucks
Code icu 140 columbia detroid engine
I googled: icu 140 columbia detroit engine
There are a number of answers. They should help.
May 07, 2015 | Freightliner Columbia Dash Panel: 2002...
2006 Freightliner 60 series Detroit throwing the following codes... 108, 117. Can anybody help tell me what they mean.
these are specific detroit / freight liner codes
take it to a service dealer as the downtime costs will be more than fixing the fault quickly
Apr 20, 2015 | Cars & Trucks
Freightliner fault codes list128
check your water level. if ok then clean your water temp sensor or level sensor
Aug 17, 2014 | Freightliner Columbia Dash Panel: 2002...
I have a freightliner argosy with detroit series 60 and smartshift. Tonight the gearbox would only change up and down in the numbered gears and came up with fault code TRANS NoRESP and some numbers. Just...
I would suggest that it is taken to a freight liner service shop but I suggest that the code reading would indicate a fault in the wiring to the gear box. Possibly a fuse or a failed connection in the wiring or a faulty module for the gear box.
May 12, 2014 | Cars & Trucks
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Locate the oil pressure sending unit on freightliner
on a 60 series detroit its behind the lower left rear of engine near steering column
Oct 18, 2009 | Lisle Oil Pressure Sending Unit Socket...
RTO Ho Herpa Freightliner Truck Tractor Logo
362 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
