Question about Electric Kid Trax C6 Corvette Ride On
Were can i download a manual for the 12v corvette ride on car pls
  • davidfoley38
    davidfoley38 Jan 11, 2013
    thnx a lot helped loads and easy to download
Posted on Jan 09, 2013
New Rastar La Ferrari 12V Red Licensed Ride on Car brand new the engine noise button does not work any idea on how to fix this ? it did work but after i tried the mp3 player it wont work
usually they run off of a different set of batteries, check if there is a screw that holds the player in, then remove the screw and check if the batteries in the back of the player are good
Jul 23, 2017 | Electric Kid Trax C6 Corvette Ride On
Kid Trax KT1021 Corvette does not start or even make a noise but meter shows battery & charger are both good and that the board is getting juice. We have followed every wire multiple times, looked at...
Safety 1st, KidTrax Battery-Powered Ride-On Vehicles Recalled Dorel is recalling about 141,000 Safety 1st and Kid Trax battery-powered ride-on toy vehicles. An electronic malfunction can occur in the circuit board and/or battery connector, resulting in smoking and melting of components.
This poses a vehicle fire hazard and a burn hazard to consumers if components are touched while malfunctioning.
The firm has received 49 reports of overheating or melting components on the ride-on vehicles. No injuries have been reported.
The recalled battery-powered ride-on vehicles include the Pink Corvette, Torch Red Corvette, Yellow Race Car Corvette, Red Electroplate Corvette, Fire Engine, and Batmobile with the model numbers listed in the chart below. They were sold under the brands Safety 1st and Kid Trax by Safety 1st.
The ride-on vehicles were manufactured between January 2004 and August 2005. The manufacture date is located on the underside of the unit and is molded into the plastic body as shown. The circle on left displays the month of manufacture, the circle on the right displays the year of manufacture. The model numbers are located on the underside of the vehicles near the date code.
Ride-On Vehicle Name Model Safety 1st Pink Corvette 50503/50503A Safety 1st Torch Red Corvette 50504/50504A Safety 1st Yellow Race Car Corvette 50505/50505A Safety 1st Red Electroplate Corvette 50521/50521A Kid Trax Fire Engine 50506/50506A Safety 1st Batmobile 50527
The units were sold at major toy stores and mass merchandise outlets nationwide under the brands Safety 1st and Kid Trax by Safety 1st from January 2004 through August 2005 for about $300.
Consumers should take the recalled ride-on vehicles away from children immediately and contact the company for a free repair.
For additional information, contact Dorel Juvenile Groups Ride-On hotline toll-free at (866) 611-3022 between 8 a.m. and 4:30 p.m. ET Monday through Friday, or visit www.djgusa.com.
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC).
Sep 23, 2017 | Peg Perego 12 Volt Rechargeable Battery
AIR RIDE FOR MY 95 VETTE
I guess I need to start by saying I am not a Corvette expert, and this may not be of much help. The folks who answer questions are all volunteers like me.
The C4 series Corvette which includes your model year came with two options. The FX3 option was a selective ride suspension control which used special shocks that a computer dialed to either standard or performance mode depending on the driver's choice and road conditions. The only thing different from cars without the option was the special shocks and some sensors.
The other option was Z07 which was adjustable or special suspension. The Z07 option was supposed to include special sway bars, springs, and wheels plus the FX3 package.
I'm not finding anything about a factory air suspension system. Thats not to say it did not exist. There are lots of aftermarket kits to put air bags on a Vette.
Normally, as long as the ride height is normal, a rough ride would be attributed to bad shocks or struts.
The FX3 system included a computer that did a self-check when you started the car. As long as you did not see a light saying Service SRS or SRC everything was ok. SRS in this case was for Special Ride or Sport Ride Suspension and SRC was for Service Ride Control. If the light stayed on the computer was scanned for trouble codes like the engine computer.
Do you know if the air ride is a factory install ?
Jul 07, 2013 | Cars & Trucks
How to install f55 rear shocks on my 2003 corvette
Disconnect the wiring, unbolt the shocks, remove tie rod nut and remove tie rod from control arm, remove and replace the shocks and reconnect the wiring.
May 19, 2010 | 2003 Chevrolet Corvette
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Horn and cigar lighter not working on 1982 corvette - need wiring diagram
Visually inspect horn make sure its not corroded and wiring is on it tight. Then use a voltmeter and when horn button is depressed 12v should register on the meter. If 12v are there and horn doesn't sound the horn is defective. If 12v does not make it there then its either the relay or clock spring (located inside steering wheel) most likely. A visual inspection should pretty much do it with the clock spring (corrosion ,wear of contacts). Relay must have B+ going to it at all times and coming out only when horn is depressed. good luck
Oct 27, 2009 | 1981 Chevrolet Corvette
My 1989 Chevy Corvette,( 350 automatic ) the
More than likely the heater valve is stuck open. You can usually purchase them from the local parts house. As far as the ride most of these cars ride this way. You can update the suspension with newer designs and shocks to allow a softer ride and can even get suspension that is adjustable allowing you to set the ride and performance yourself to your liking. Air suspension is probably also available to allow maximum soft ride.
Sep 23, 2009 | 1989 Chevrolet Corvette
No a/c and "service ride control" is on after replacing radiator on 99 C5 corvette
ine did that,and i have a blowed fuse,,,and my light came on when they unpluged the wires,,i had to erase the light with a programer..
May 27, 2009 | 1999 Chevrolet Corvette
Electric Kid Trax C6 Corvette  Ride On Logo
270 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
