Question about SAMTRON 55V 15" CRT Monitor
SAMTRON 56V 15 in.CRT A41DC IC PROGRAM
Hello me manju my problm : i repaired samtron 56v monitor in which regulator 7805 was bad (output high voltage insted of 5v it was 8v)i replaced it, now memory ic A41DC (8pin) does not holds screen settings. i replaced the ic with C41DC after replaceing it works for one time, after switching off & again ON the same problm comes , so pls experts help me
  • bahu Jul 17, 2008
    SAMTRON 56V 15 in.CRT A41DC IC problame in my moniter please halp me
  • Anonymous Feb 19, 2009
  • 49 Answers
Replaced the memory with exact part number.if same problem exist ur system gone bad because u said that the 7805 failed(overvoltage) which is also the supply of system control. hope this help u...
Posted on May 17, 2007
I have samtron 56v monitor,when i check the secondary power . it is too low. how can get the problem. please help me.
thanks
praveen
Posted on Sep 01, 2010
I have Samtron 56v colour monitor. It is not powering on. I have to press the switch several times to power it on.Otherwise I have to slap on it & then switch it on than only it starts.Please tell me if you have any solution for this.
THANKS
Posted on Sep 01, 2009
When i switch on my computer the cpu is running normally but my monitor not working.when i press the monitor switch the green light comes & when i release the green light gone.I think switch problem.what to do?
Posted on Sep 08, 2009
  • krishnamurthy adhyapak
    krishnamurthy adhyapak Jun 09, 2014
    same problem with my monitor also please sujjest how to solve this,
MY BIOS LOST HIS DATA.
Posted on Dec 25, 2007
How to stop monitor menu pop up in my Desktop's CRT Monitor ? The menu pop up keeps coming back and I have to keep exiting manually using monitor menu buttons.
r u sure about model number.bcoz 55v does't come with menu.
replace regulator 7805 near microcontroller if it is model 56v.
Aug 22, 2010 | SAMTRON 55V 15" CRT Monitor
Tip
Samsung ctr 56v model monitor does not working
I am a technician.
i was replace the memory ic, 7805 ic, micor ic, and driver ic.
but SMPS is good working.
on Jan 26, 2008 | SAMTRON 55V 15" CRT Monitor
I HAVE SAMTROM MONITOR OF 56V IF I SWITCH ON COMPUTER IN CENTRE THE CONTROL LOCK APPEARS FOR HOW TO REMOVE IT IT STAYS NEAR 20 TO 30 MINUTES
get it repair or it would be wrost...because in this fault 5 volt regulator i.e 7805 gets malfunctioned and it may led to switch off your monitor.
Aug 21, 2010 | SAMTRON 55V 15" CRT Monitor
I have a Problem in vga cable of my Samtron 56V Monitor.. Pls tel me how to replace
connect another cable as follows
1-red
2-green
3-blue
4-gnd
5-gnd
6-red gnd
7-green gnd
8-blue gnd
9-+5v from display card
10-stand by
11-synchronus ground
12-sda
13-hsync
14-vsync
15-scl
the numbers of pin are given
under pin
May 20, 2010 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor control is locked
hold the menu button for 10-15 seconds.this shld unlock the menu. if the menu window still keeps popping up then u shld change either memory ic or power regulator..
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56V monitor
Even i was also having the same problem. We can unlock the control lock by holding the menu button for 10-20 seconds.... But now my problem is the message "Controls locked/" appears continuously. Screen width also reduced. If anyone know the solution for this please help. thanks in advance.
Surya
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v moniter on but wosulation not coming
samtron 56v monitor wosulation problem how can i sovle this problem
Sep 28, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
Screen menu displays locked & unlocked
Hold down the menu button for 5 seconds (with the monitor turned on). It should reset the lock option.
Mar 11, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
1,103 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
pankaj rautela
pankaj rautela
Richard Lilja
Richard Lilja
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
