Question about Canton AS 60 SC Subwoofer
Subwoofer is making thumping sounds, how do you fix?
Thumping sound started?
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
Intermittent thumping sound from the subwoofer!
Check for it grounding out somewhere or the ground wire isn't grounded well. If all is well it is internal in your amp.
Aug 02, 2012 | Bose Companion 3 Computer Speakers
I just purchased a Lenovo desktop IdeaCentre K320, MTM:30192GU. It makes a thumping sound from the hard drive. Is there a fix? If not I will return computer to store. Then I went online and saw the...
Take it back. A hard drive should not make any sounds. Lenovo is somewhat infamous for clicking, grinding and thumping sounds from their hard drives.
Take care, and good luck Wei
Feb 02, 2011 | Computers & Internet
My subwoofer (Altec Lansing[AVS500]) is always makeing a thumping
You could only verify this by gaining access to the rear of the speaker but I suspect that the 'spider' has come unglued. This is a device that surrounds the lower (inner) end of the cone to provide a second point of suspension; without this, the voice coil can slap against the side or bottom of the magnet structure.
I don't think a repair is an economical choice for these; repairs only make sense for 'professional' speakers that cost several hundred dollars to replace.
Apr 13, 2009 | Altec Lansing 621 Computer Speakers
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
Apr 02, 2009 | JBL PB12 Subwoofer
96 buick century makes thumping noise when higher rpm is reached
Sounds like a classic motor mount problem. Might want to get the dogbone strut checked as well.
Sep 27, 2008 | 1996 Buick Century
Sunfire True Sub Constant Hum & Thump on Initial Signal
IF THE SUB HAS AUTO SIGNAL SWITCH THIS OFF BUT TO BE HONEST IT SOUNDS LIKE YOU HAVE A SPLIT VOICE COIL.
Jun 20, 2008 | Sunfire True Sub Signature Subwoofer
Constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
May 24, 2008 | Kenmore 63942 Dryer
Canton AS 60 SC Subwoofer Logo
74 people viewed this question
Top Canton Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Owen Barnes
Tom Chichester
Are you a Canton Audio Player and Recorder Expert? Answer questions, earn points and help others
