Copier drum reset code
What is the code to reset the drum counter on this Sharp AL1340 copier?
  • Richard Michael
    Richard Michael Jan 06, 2009
    I'll be trying that code before long. The first indication (17,000 copies) has shown up and I'll be installing new drum in current carrier when I hit 18,000 copies. Thanks ever so much.
    Gobarnto
  • nazeersaleem Jan 15, 2009
    would not make copies with a new toner cartridge. i will chage drum when I can afford
    Thanks
    President:
  • Office Equip... Master
  • 990 Answers
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Posted on Jan 05, 2009
Msg on my Sharp MX2300N
The TA code refers to the maintenance cycle of the copier. Its the copiers way of saying ''come and see if im ok''. I would recommend resetting the maintenance counters for your drums, developer, fuser and transfer belts. This can be done in the engineers menus.
May 06, 2013 | Sharp MX-2300N Color Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
I tried drum reset code for Sharp AL2040CS. The problem
code is not true.enter (C interrupt zero interrupt)42 start 1 start
Feb 18, 2010 | Sharp AL 1631 Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
How do you replace the drum in Sharp AR M450N copier?
Basicly, any screws that are Blue in color can be removed. It is very easy to do if you know how Sharps are... You may be getting your self above your head... You also, have to reset the drum counter & drum cycle counters... Good Luck
Jun 12, 2009 | Sharp AR-M450N Copier
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
Reset the copier counter AL-1641CS
Which reset are you trying to preform
the counter for the drum unit ?
Apr 01, 2009 | Sharp AL-1641CS Copier
Sharp Al1340 copier/Printer drum light blinking I realize i need to change the drum but meanwhile i woould like to continue to use it for afew moore weeks. Is it possible. I need a drum change code to...
Enter C(key) Auto (key) C (key) Auto (key)  so the panel power off. Press number copiers 24 and press print key, press number copiers 07 and press print again. Click C (key)  4 times. Now lamp drum  light on with + 18000 copiers. Good Luck!
Jan 15, 2009 | Sharp AL 1631 Copier
Drum light
Check a service manual on resetting the drum counter. You have to reset this counter to tell the machine it has a new drum
Aug 25, 2007 | Sharp AL-1641CS Color Copier
547 people viewed this question
jasbo
jasbo
