Question about Mitel 9104-001-000 Power Supply SX-50 (9104001000) Power Supply
Disabling mitel sx50 trunk loop back error
Loop back error alarm keeps going off...how do i stop it??
4 Suggested Answers
  • 378 Answers
SOURCE: I HAVE MITEL SX50 AND
The phone is either off hook or the line is shorted out somehow. If it's shorted out, it's likely a jack and you should replace it. I suggest you contact your vendor for assistance.
Posted on Apr 22, 2011
  • 378 Answers
SOURCE: I HAVE MITEL SX50 AND THERS ONE EXT THAT IT SHOWS
The extension is shorted somehow - likely corrosion on the jack. Replace the jack and see if that corrects it.
If it doesn't, contact your vendor for assistance.
SOURCE: How can i fix lock
How do i unlock and extension that is locked? It doesnt have a dial tone on the phone in the room and on the console it shows the extionsion is locked how do i fix this anyone with a suggestion can email me at baby_doll67410@yahoo.com
Posted on Jun 26, 2011
Is phantom calling rooms 1am to 6am there are no alarms set all cleared.
Pull the plug on the whole system for 5 minutes and plug it back in and it will reset its faults.
Jan 04, 2016 | Mitel SX-50 SX50 MS-55 PBX PHONE SYSTEM...
I changed the battery and the alarm wont stop going off
You need to disable the alarm with the key in the door. Hook the battery up, then just stick the key in the door and unlock it. If you have door lock problems, you should be able to disable the alarm by opening the trunk with the key.
Feb 20, 2011 | 1995 Volkswagen Jetta
Disable external calls on mitel 3300
This is a function your phone vendor will need to complete for you specifically they will need to setup a Class of Restriction for the set that you would like to block from using your outbound trunks.
Nov 25, 2009 | Mitel 5212 IP Phone
Mitel SX50 busy signal
sounds like ur pstn gateway is the cause check all connections and make sure that the sytem is completely unpowered then plug in restart and test a local call, leave line open and see what it does
Jul 10, 2009 | Uniden 5.8GHz Cordless Phone
Mitel SX50 Equipment Busy Problem
Press "function", then 32. This will clear all alarms and error codes.
Apr 06, 2009 | Uniden 5.8GHz Cordless Phone
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
CAR ALARM
We have a similar problem - it doesn't go off when we open the door, but sometimes the alarm light stays on after we open the door and then when we put the key in the ignition to start the car the alarm goes off. The only thing we've found to shut the alarm off is to get out of the car and put the key in the trunk manually and open the trunk. Then after we've opened and closed the trunk, the alarm disables and then we can unlock the doors (which I believe is the step where the alarm disables) and then we can start the car without a problem.
Aug 04, 2008 | 1999 Volkswagen Jetta
Computers & Internet Logo
212 people viewed this question
Top Mitel Computers & Internet Experts
Martin Murray
Kelley Hopper
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
