Question about Hunter 52" Ceiling Fan With Light And Remote Control
How to replace the remote receiver on hunter fan #28191
Purchased new remote receiver for ceiling fan and need directions to replace.
  • 323 Answers
SOURCE: Remote not working fan...
You can get them a Home Depot. You may have to buy the receiver and the remote together.
Posted on May 26, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: I have a Hunter Ceiling Fan Model # 23529. The
The receiver part #8511204000 and runs like $50 plus shipping....if its the remote the replacement part# 23529-300 and it runs like $40 plus shipping. You can order it from Hunter or other Hunter dealers.
Posted on Sep 03, 2010
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
I need to purchase a Hunter ceiling fan receiver. The receiver model # is 85069-060.
hunter technical support number is-- 1-888-830-1326 call this number and they should be able to help. good-day ! just tell them you need a new receiver, and give them the model number of the receiver and the fan model number.
Aug 25, 2011 | Hunter Ceiling Fan Remote Receiver...
I need a hunter's ceiling fan remote part# 85095-01 can you help me?
To my knowledge there are not parts available for remotes. Have you checked to be sure that all your dip switches are coded identically, receiver and transmitter. There are no servicable parts on the remotes. You can purchase a new remote & receiver at Home Depot for $29.00. Be sure you have 120 volt at your fan and check your remote batteries.
Aug 22, 2011 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Jun 20, 2009 | Hunter Ceiling Fan Remote Receiver...
Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
Feb 28, 2009 | Hunter Ceiling Fan Remote Receiver...
Dryers Logo
59 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
