Question about Bosch Washing Machines
Bosch logixx 7 stopped mid cycle
Electric went off mid cycle. machine flashing 400 & spin & end. plus bleeping to freak me out.
Yozzer6821
  • 116 Answers
SOURCE: Door lock light flashing
More likely the PCB needs replacing - common fault, you could try a new door switch first cost £5 new PCB £65+ but is easy to replace.
Posted on Nov 09, 2008
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
vickygomar
  • 460 Answers
SOURCE: washing machine stops mid-cycle
F30
DISPENSER SYSTEM ERROR
when the dispenser motor cannot be driven to its proper positon.
==========The following information is for a TECHNICION SERVICE(only)========
1.- Unplug washer or disconnect power.
2.- Check mechanical linkage from dispenser motor to the top of the dispenser.
3.- Check wire hamess connections to the dispenser motot and Central Contol Unit(CCU)
4.-Check dispenser motor for power rotation.
Was this helpful?
Posted on May 12, 2009
SOURCE: Bosch Maxx 1000 front loader starts but stops
Have one of these machines and when on the drying cycle the drum started pushing the machine around the kitchen and making a very bad sound so we stopped it before it blew up. On looking at the internal workings we can see a screw and part of the plastic housing that held it in place fell to the floor. It appears to be part of a frame that holds a metal brace in place that holds the drum in place and ensure that it joins the door to the machine. To me it looks as thought the machie is capable of washing but if we use it to dry it will damage itself and breakdown. Anyone else had this problem and any solutions.
Posted on Dec 21, 2009
  • 662 Answers
SOURCE: bosch logixx 1400 express washing machine spin is
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Posted on Jun 15, 2010
Bosch logixx 7 (5 years old) Serial No WIS24140GB/07 door will not open at end of programme. start/pause, 400, rinse, spin & end lights all flashing and a bleeping sound. To open door have to switch to off...
After trying to find manual and doing it the right way with no success my son solved the door problem with a metal fork. Where your hand meets the handle (inside the door drum) shove the fork in to force the clip open. Not the outer edge of the door, theres no locking system there - behind the actual handle.
Aug 29, 2013 | Washing Machines
Mid cycle it turns off and beeps and the anti crease/end button flashes
Possibly a blockage pump or drain outlet, check the filter behind the flap (bottom right on the kick panel).
May 31, 2013 | Bosch Logixx WFT 2806 Front Load...
Bosch logixx 8 end cycle bleep
Send me detail about your product, model and manufacturer.
I think I can Solve it.
Apr 20, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hi How do you remove the child lock on a Bosch Front loading washing machine Logixx 8
Hi
Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Thanks for contacting fixya.com
Nov 13, 2009 | Bosch Washing Machines
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
