Question about Epson Stylus Photo R320 InkJet Printer
General error on my epson stylus photo r320-
I continue to get this general error message, and I just pressed the power button and the stop button at the same time, and now I'm unable to even power up the printer.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Epson R320. Had a "end of life" message so I held done the Power/Maintainence/Stop buttons for 10 secs and nothing happend. Held them again and unplugged it, plugged it back in and pressed Power and now...
The R320 is not compatible with the keypad press routine if I remember correctly so you really need a utility that can work with it.
I've had a quick check and found that the A10_IPR is capable of handling the reset for that model but for completeness here's the link for all the current info I have on the R320 in terms of resetting and fitting an external waste tank which you'll want to consider to avoid the printer flooding with waste ink.
Hope it's of some use but let me know if you're still borked after trying.
Martin
Aug 01, 2010 | Epson Stylus Photo R320 InkJet Printer
How to fix a sysytem error message on a epson photo r320 printer. my printer is displaying a system error message and tells me to hold the stop and power button for 7 seconds. But, after I do this and...
The Solution is simple: Unplug your printer then remove all the catridges then turn it on. Then the printer will display error indicating no catridges then put back the catridges then it will automatically reset your printer thats all folks...Please comment if it works for u...
Jul 17, 2010 | Epson Stylus Photo R320 InkJet Printer
Any info on r320 general error fix . Had a paper jam and cant reset error. epson support usesless just say tech it to an authorized dealer to get it fixed.
1. you may have paper debris in the roller gear and therefore shut down.
2. you roller or transfer gear is damaged and needs replacement.
Apr 15, 2010 | Epson Stylus Photo R320 InkJet Printer
General Error Message
The "General error" message on the Epson R320 (as with most other Epson inkjets) can mean a whole host of things.
The most common ones are:
  • Printhead carriage blocked
    (something is blocking the printhead from moving left and/or right properly)
  • Cleaning/Parking pad area blocked
    (the printhead can't reach it's normal resting position)
  • Disconnected sensor
    (a ribbon cable has become disconnected or a sensor has failed so the printhead or paper location is not detectable)
  • Cartridge chip sensor issue
    (one or more of the cartridges has not been installed properly, has a "bad" chip or the sensor wires in the printhead carriage [where the cartridges sit] have been damaged)
If you can provide a bit more information on the error, possibly from the status monitor software that might give a bit more of a clue but hopefully the points above will give you a few places to look for possible causes.
Mar 15, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
General error
i have some problum of epson r230 printer general eror please send me this problum solution
thanks
Oct 20, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson r320 System error. Press and hold both Power and Stop buttons for 7 seconds
This could be the Ink Overflow Protection Error. If it is you may need to get a Rescue Kit for your machine form http://www.TheServiceManualShop.com Does the status monitor or LCD indicate that parts inside are past there service life?
Aug 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson r300 printer
step1..............switch on
step2............press+hold stop,ink,power buttons untill printer switches self of
step3............switch back on and problems should have gone
Aug 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
438 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
