Question about Makita G6100R 5800 Watt Generator
Makita 6100r generator doesn't seem to auto idle
Hey guys. Have a makita 6100r generator that runs and starts a ok. It had been laid up since last storm season, with some gas in the tank that had been sta bil'd. Starts up ok, but doesn't seem to auto idle. I've only had minor loads on it, but with zero load, and the auto idle switch "on" there is no difference in idle, it seems to be running flat out. Thoughts? Thanks
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: Makita G11oo portable generator. starts on choke. cuts off run
Just noticed your question... If you still need a little help:
1. If the gas is from last year, drain the tank and the carb bowl and replace gas with new. Visually inspect the inside of the tank ..be sure there's no sediment that needs to be cleaned out.
2. remove air cleaner and make sure it's not plugged or dirty
3. plug the spark plug and clean with spray carb cleaner.
4. At end of season, mix some gas stablizer in with the fuel to keep it from going bad while in storage.
Let me know how it goes..
k
Posted on May 31, 2009
  • 142 Answers
SOURCE: auto idle does not work propertly on makita g 6101 generator
The battery charging is also a load. If the battery is not well charged or old it may need about 60 - 120 W to charge, which is not "Idle".
Posted on Jun 26, 2010
freetek
  • 5568 Answers
SOURCE: Hi, I recently purchased a used makita 6100r
You may be asking too much of the unit; the 5800 watts a which it is spec'd, may be a 'peak' power rating which may be 15-20% higher than its continuous rating. 30 Amps at 220 volts implies 6600 watts which is higher than even the peak power rating. I would expect the unit to produce ~4800 watts continuous or around 22 Amps.
Decided to check my statements and found this, which I quote:
Generator Volts AC (60Hz) 120/240 Max. Output Current 5800W-48.3A/24.2A Rated Output Current 4800W-40A/20A Volts DC (AMPS) 12 (8.3)
Posted on Aug 28, 2011
What does a diode stack assmelly do on my
makita g5501r parts Power Generators Questions & Answers
www.fixya.com > Forum > Tags > makita g5501r parts
Power Generators makita g5501r parts questions and answers. ... I own a makita 6100generator and it is only putting out about 105 volts ac and about 208 volts .
Nov 18, 2015 | Makita Electrical Supplies
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
My makita rbc420e starts ok ticks over but will not rev I think it's a fuel problem
take off the muffler and try it if ok open the muffler and clean off the screen
May 08, 2012 | Garden
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
Hi, I recently purchased a used makita 6100r generator and when checking it out I discovered on my 30 amp 220 receptacles arent getting full power. I took out the receptacle and checked the wires in back...
Aug 28, 2011 | Makita G6100R 5800 Watt Generator
What tipe of oil makita generator g1100 takes
Great generator, i use 15/40 Quaker State it seems to work well for my uses, i have same one, but is 2000. check your manual if your really concerned, the whole thing, is keep oil fuel, and changed often. Hope this helps mike
Jun 13, 2011 | Makita G1100 1100W Generator
Auto idle does not work propertly on makita g 6101 generator
Jun 24, 2010 | Makita G6100R 5800 Watt Generator
k
May 21, 2009 | Makita 1,100 Watt 2.5 Hp Portable Power...
Makita G6100R 5800 Watt Generator Logo
147 people viewed this question
Top Makita Electrical Supplies Experts
obsteiner
Tom Chichester
Ogbonna promise
Are you a Makita Electrical Supply Expert? Answer questions, earn points and help others
