Question about Brother IntelliFax-4100e Fax
Smells hot and doesn't work
Intellifax 4100e was working until it smelled like something was burning. At that point it would not do anything. Is there a way I can remove the cover to see what might be damaged inside the machine?
Do you think it's worth repairing?
    Problem Solver:
  • 8 Answers
Unfortunatley, with laser printers it is not unusual to notice a burning smell. Sometimes that could mean that there is paper jammed inside your fuser assembly and it is being burned when power is applied. However, there could be a number of reasons why the machine won't function. My recommendation is to have a certified technician look at the machine for you. It may cost you $45-$75 to have someone check it out for and tell you what the cost would be to fix.
Posted on Jan 04, 2009
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
I started my car and it is missing and smells like rotten eggs and burning,what is doing this?
Did you add anything to the car. Amp/stereo ? anything? If not then you have a ground or hot/positive problem (check round points and hot wire points). If you added something, you cut into the wrong wire for power.
Sep 04, 2014 | 2001 Chevrolet Cavalier
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
Xantrex inverter/ charger smells like burning electrical
I would call or e-mail the manufacturer of the inverter. The dealer or dealers may know the issue but likely the manufacturer will be more help.
Some devices like an inverter will have a smell in the beginning, power supplies are like that. You said that the inverter didn't get hot but smell indicates something is hot.
Apr 13, 2017 | Xantrex Electronics - Others
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
Burning smell when I warm up the car
check to make sure you dont have anything (plastic bag, etc) burned and stuck on the exhaust, othere than that it could be a normal smell associted with the different materials getting hot, i would compare it to another like vehicle and see, could also be trapped odors in the heater core caused by a previous smoker or bacteria growing, gm sells an odor elimnator that works pretty well
Jan 15, 2013 | 2009 Chevrolet Aveo
What's your problem?1996 chevy cavalier dash warning light has a red arrow pointing towards water and car smells like something is burning P
The light does it say Water? You are sure about this? Please have this checked by a mechanic asap,. if it is starting to run hot if you catch it early then you can avoid serious damage to the engine. The smell may be a leaking engine water pump or other component of the engines cooling sytstem.
Feb 29, 2012 | 1996 Chevrolet Cavalier
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Smell like a electrical smell ocassionaly coming
Its probably getting hot so you might smell the components heating up. I would try to if possible clear up some space and try cleaning the unit with a air can. Try to get dust that builds up over time
Sep 09, 2009 | Parasound HCA-750A 2-Channel Amplifier
Brother IntelliFax-4100e Fax Logo
118 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
