Question about Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness
How do I adjust the tension on a pinnacle 27 laminator
GBC Pinnacle 27. Right side top heat shoe does not get as hot as left side. Lamination is milky colored on right side
Could be one of the elimebts have burnt out as there are more than one into the tip just take to local shoe repiar as taking it to golf shop will be expensive
Sep 03, 2016 | Cars & Trucks
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
GBC Pinnacle27 Laminator has no control board power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......Westco Laminating Service 405-324-6092.
Jan 08, 2014 | GENERAL BINDING CORPORATION Laminating...
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
I have a Pinnacle 27 EZ load Laminator that keeps showing an ERROR CODE 02, nothing in my service manual showes me what this problem is, the unit will not run, HELP!
have no idea what the code means but i would hazard a guess and say the heater circuit isnt working ,take it apart and try a volt meter across the heater element
Dec 16, 2010 | Office Equipment & Supplies
1998 dodge neon airconditioning belt adjustment?
This procedure involves correcting the tension on the power steering accessory and A/C compressor drive belt.
1. Loosen the power steering pump locking bolts A and B and pivot bolt C(Illustration 1 and 2 ) to allow adjustment of belt tension.
2. Using a 1/2" breaker bar, adjust belt tension by applying torque to the square hole "D" on the power steering pivot bracket. Adjust the tension as follows:
Belt tension with no belt replacement: A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 100 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
Belt tension with belt replacement:
A. Using the Belt Tension Gauge Special Tool Kit C-4162, adjust the belt tension to 135 lb.
B. Tighten in order, first tighten the locking bolt A to 27 Nm (20 ft. Ibs) then, bolt B to 27Nm (20 ft. Ibs). Finally tighten the pivot bolt C to 54 Nm (40 ft. Ibs).
C. Start the engine and allow the vehicle to idle for 15 minutes to allow the belt to seat.
D. Repeat the belt tensioning procedure, set belt tension to 135 lb.
click here for picture 1
click here for picture 2
Jun 13, 2008 | 1998 Dodge Neon
Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness Logo
172 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
