Question about Vivitar Auto Thyristor 3200 Dm/c Canon Film Camera Flash
My Vivitar 3200A flash will not work. When I switch it on light the Lamp ready light turns orange immediately. Could the problem be in the Thyristor and what can I do?
  • 8 Answers
SOURCE: no 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Posted on Jan 29, 2008
  • 48 Answers
SOURCE: Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Posted on Mar 08, 2009
SOURCE: Need a Vivitary Thyristor 285 Flash Owner's Manual
Well give me a few days to look in my endless piles of stuff and I might have one I can scan for you.
epace@juno.com
Posted on Apr 30, 2009
  • 302 Answers
SOURCE: Older Vivitar Flash for new Canon SX10
Not compatible.
Get slave triggers and use them as remote flashes, or buy another film camera.
It seems Vivitar no longer is in the flash business. Get a Sigma or Sunpak digital flash for your SX10
Posted on Oct 20, 2009
  • 50 Answers
SOURCE: Vivitar 8400 will not turn on. When switching on,
This is more than likely a Manufacturing problem. A lot of Vivitar cameras have this problem as well as many others that are usually not the consumers fault. Just a glitch in the technology. I alone have gone through four Vivitar cameras in the last six months. The best thing to do is contact Vivitar directly. This is there website: www.vivitar.com It is best to see if you can find the number for technical support. To see if they can give you a refund or replace it for you. I hope this helps. -Richard
Posted on Apr 12, 2010
Not compatible.
Aug 28, 2009 | Vivitar 285HV Flash
epace@juno.com
Apr 21, 2009 | Vivitar Cameras
I can't make the flash work,
Are you serious...you don't know how to turn it on? Ever wonder what the on/off switch is for?
Slide the switch from left to right and wait for the 'ready' light to change from red to green...then it's ready to shoot.
Mar 18, 2009 | Vivitar 285HV Flash
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
Ready lamp on 283
When the flash goes into battery saver mode, which it does automatically, the light will blink.
If you are using the external power source, the light should remain steady.
Jeff
Oct 30, 2008 | Vivitar 283 Flash
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
No 'green' light on bacl of my 'old' Vivitar 285
Nov 30, 2007 | Vivitar 285HV Flash
Vivitar 283 charges but fails to flash
I had the same problem with my early Vivitar 283 flash.  I discovered that the thyristor on the trigger board tested as an open circuit.
Trying to find a replacement for a 30 year old thyristor semi-conductor proved to be fruitless.
My solution was to purchase a broken, late model Japanese 283 flash off of ebay and transfer the trigger board to my early Japanese model. The late model thyristors could handle more heat.
Problem solved.
Mar 15, 2007 | Vivitar 283 Flash
Vivitar Auto Thyristor 3200 Dm/c Canon Film Camera Flash Logo
44 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
