Question about Toshiba Satellite A135-S4527 Notebook
The sound icon in tray is gone
I cant get any sound? the icon in tray is gone. everything is turned on in control panel.
  • Toshiba Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the side of the laptop
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers
click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope this helps
Posted on Oct 29, 2012
2 Suggested Answers
  • 7 Answers
SOURCE: my toshiba satellite laptop sounds suddenly gone
you will have to get this fixed as the speaker has gone bust. As i had the same problem
Posted on Apr 07, 2010
I didnt want KNctr I want it deleted but cant dont know how this showed up on my comptuer.
Down on the right corner of your desktop you will see some small icons next to the clock (Thats called the system tray area). There may be an arrow in the system tray if your pc isn't set to show all items in the system tray. If you place your mouse over each icon in system tray one of them should say its the 'knctr icon'. Right mouse click the icon and then left click 'Shutdown'. After that go in to the control panel -> programs and features -> find the program on the list and 'Uninstall' the program. Reboot after uninstall and it should be gone.
Hope that helps.
Alex
Head of Tech Geek and More
TechGeekandMore.com
Oct 30, 2013 | Computers & Internet
My volume icon on the task bar has disappeared, how do I get it back
Open the TASK MANAGER, open the PROCESSES tab, highlight "explorer.exe", click on "end process", Open "file", "New Task", Type "explorer" without quotation marks. OR Control Panel, Sound, depending on your OS, You will find a box to show tray icon. If it is checked, uncheck, apply, then check, apply. The Task Manager will remove stored icons that fill the program, and restart the icons.
Nov 28, 2012 | Dell Inspiron 1501 Laptop
I cant hear sound for my computer
Assuming you used to hear sounds, you could have one of several problems.
1) Your speakers are turned off (is the little light on the speakers green?)
2) The volume is turned down or muted. Check to be sure you haven't accidentally muted them. You can find this out by clicking the little speaker icon in the system tray and seeing if the mute box is checked or check the sounds icon in the control panel.
3) Something happened to the sound driver. If you are in the Control Panel and click on sounds, you should see the various sound assigned to computer events. If you click the arrow to test play the sound and the little arrow is grayed out, then the sound drivers are missing or corrupt and must be reloaded.
4) Your speakers could be bad.
Apr 01, 2011 | E-Machines W3503 PC Desktop
I cant hear any sound from the built in speakers
Ensure that the system volume is turned up and not muted. There should be an icon for the volume controls in your system tray at the bottom right of the screen. Or you can click on Start > Control Panel > Sound.
Mar 18, 2011 | IBM ThinkCenter A50 (841937U) PC Desktop
Everything is plugged in and this morning the simply woul;dnt work i cant get any sound from the speakers either, do you have any tips
Has something changed your default playback device?
USB devices can sometimes do this.
Right click on the speaker icon in system tray, or go to sound properties in control panel
Sep 16, 2010 | Logitech Z-2300 Computer Speakers
Cant access volume control after downloading driver
If you mean the Volume icon in the system tray then you have to make it visible by Start->Control Panel->Sounds and Audio Device Properties. here you will fing an option where it says Place Volume Icon in System tray. Just click its box.
Jan 13, 2010 | Toshiba Satellite L25-S119 Notebook
My sound doesnt work. I cant click anything like mute nothing, because of that i cant follow the steps on help and support.
depending on if the sound is actualy not working or just the icon in the tray is missing.
goto Start-control panel - sounds
see if there is a check place to put sound icon in the tasktray.
click on windows sounds to see if there is a sound card installed
Oct 10, 2009 | IBM Computers & Internet
Icon for speakers gone
Dear Jesuslovsu,
Please go to control panel --> Sound and Audio device properties and select the check box that says "Place volume icon in the taskbar"
If these controls are greyed out then you might want to install the sound card drivers ones again... The CD might have come along with your computer purchase kit.
If that doesn't resolve the issue then kindly let me know and I would be glad to assist you ahead.
Hope that helps.
Regards,
Srinivas
Jun 19, 2009 | Compaq Presario SR1000T (568657) PC...
Network problem
go to control panel
network connections
locate your wireless connection and right click on it
left click properties
locate the tick box that says shown icon in taskbar and put a tick in the box
ok everything to return to desktop
your icon should now be in the system tray
Jan 06, 2009 | Computers & Internet
Missing icon
click 'control panel'
click 'Sounds and Audio Devices'
Check the box that says 'Place volume icon in the task bar'
Dec 11, 2008 | Gateway GT5404 PC Desktop
Toshiba Satellite A135-S4527 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
