Question about 1A Auto Parts 2000 Chevy S10 Blazer GM Style Black Lug Nut Cap Set of 5 for Mod
My 2000 S-10 Chevy Blazer is overheating. I took the radiator cap off and don't see the water flooding through.
    Problem Solver:
  • 10 Answers
Sounds like your thermostat is not working right , I would replace it and see if that will fix the problem.
Posted on Oct 29, 2012
Testimonial: "I replaced the thermostat, then I notice the water was not circulating so I replace the water pump and problem fix. Thanks for your help! ."
  • James Oct 31, 2012
1998 Chevy Lumina 3.1 overheating - top radiator hose collapses on throttle, then opens up when you let off.
With the engine cold remove the radiator cap. Start the engine. Watch the coolant. If you see bubbles constantly perkulating out of the coolant than you most likely have a head gasket that has failed. If you don't see a constant perkulation of air bubbles it probably wouldn't hurt to replace the upper hose and see if the problem is resolved.
Jan 13, 2012 | Chevrolet Lumina Cars & Trucks
2001 chevy cavalier, was overheating and took out thermostat, let it idle then was not over heating,bought new thermostat put it in then overheated what do i do?
Physically look in the radiator under the cap(if one exsist's) when cool, for coolant level, and check the valve in the cap for sticking. If air is present in the radiator it can't get out, and more coolant can't get in,(from the overflow). Either clean the cap or replace it and check that it is the CORRECT cap.
If radiator is low on coolant fill it to overflowing, replace cap, and check that coolant overflow is filled to the COLD line or mark. The overflow is normally where you would add coolant. (never overfill the overflow)After refilling as outlined above, check the level every morning for 2 or 3 days until coolant level stops dropping below the cold mark and add coolant to the overflow ONLY. Do not open the radiator cap. Also, if you have even a tiny coolant leak anywhere in the system, air will get drawn in, instead of coolant from the overflow.
For more OVERHEATING PROBLEMS try these...
Radiator fins dirty, clean with a strong stream of water, not high pressure water.
Radiator clogged, try backflushing it, or replace.
Thermostat stuck open or shut, replace it.
Water pump worn out, can no longer move enough coolant, replace it.
Fan shroud broken or missing....
Electric Fan(s) not working, Check the fan, relay, fuse and engine temperature sensor's.
Belt driven fan, belt slipping, fan clutch is bad, fan blades have flattened out.
Air dam under front bumper is gone, loose, or broken. It actually has a purpose other than scraping on the driveway or curbs. It forces air up into and thru the condenser and radiator. If it's loose, airflow can actually push it out of place making it useless or blocking the airflow. Along with that, there may also be a plastic piece attached to the bottom of, and wraps up behind the bumper. If it
Aug 28, 2011 | 2001 Chevrolet Cavalier
I was having a problem with my 2000 Blazer trying to overheat. I took it in and had the thermostat and water pump replaced and also had a cooling system flush. They flushed it twice. The car has started...
how do the fins on the radiator look? straight or bent? is there any leaves or debris caught between the a/c condenser and the radiator? do you have an electric fan or a belt driven fan? does it seem to operate properly?
Aug 21, 2011 | 2000 Chevrolet Blazer
I accidently poured motor oil in my coolant and car started smoking. I't a 2001 ford taurus. What can I do to save my car and engine/ HELP!
drain the water don't use it again, Put an ordinary water and warm up the engine. Do this several times and keep observing the water on the radiator with an open cap. Use water flushing if available.. on final stage use coolant mix to radiator water.
Aug 16, 2011 | 1993 Chevrolet S-10 Blazer
Manifold water leak on 2002 blazer how do you get to it
This happens a lot with chevy engines 305 s 4.3 s its means the intake manifold gasket is leaking because the engine over heated at some point . Cheak your dip stick if you see a white fomey residue on the stick then look inside the radiator cap if you see oil floating on the top of the antifreeze it means oil and antifreeze are mixing this will kill the engine real fast so stop drivering it and have the intake manifold gasket replaced . ALso check for any other sorce of the antifreeze like a radiator hose or a gasket on the goose neck hopfuly you will find something else that easyer to fix but its a disgin problem with chevy they don't have enough bolts holding the manifold down theres 8 and there in the corners 2 in each well good luck with it
Jul 14, 2011 | Chevrolet Chevy Cars & Trucks
I have a overheating issue with my blazer. It has a 4.3 liter vortex engine, I replaced the thermostat, water pump appears to be working. Anything else I should look at
take cap off of radiator and crank motor wait for it to get to operational heat and watch in cap to see if thermostat is opening,you will see water circulating threw radiator if this doesnt happen then water pump is not working you might also flush radiator out
Jul 06, 2011 | 1995 Chevrolet Blazer
Is there not a radiator cap on a 1999 silverado? want to flush sysyem but do you refill through resavoir?
If you don't see a cap, you don't have one. If you are flushing in hopes of correcting an overheating problem, be aware that if the radiator is partially obstructed, the flush chems sold today are too mild to actually do much. The better chems were all banned by the epa.
If you are just doing routine maintenance, easiest method of draining is to remove the lower hose at the radiator, let the system drain, put the hose back on, fill with water and any chems you want to use, run it as per instructions, drain again, fill with more water and repeat with water at least twice before draining and filling with new antifreeze.(do all flushing with heater on full heat) Keep the cap off while doing this so you don't build up pressure and be careful draining hot water. Even though they are mild for the job, chems can still irritate your skin so be careful. When filling for the final time, make sure the system is full and the thermostat has opened before closing it up. Always check everything over for leaks.Any other questions? Just ask!!
May 30, 2011 | 1999 Chevrolet Silverado 1500
How to replace a radiator on a 2002 chevy blazer?
radiator needs no special tools wrenches and ratchet i would replace all hoses connecting to the radiator and thermostat would be a good idea to ensure no overheating
Nov 03, 2009 | 2002 Chevrolet Blazer
Radiator overheating
The only thing missing from your narration is the water pump. Check to make sure that you are not losing coolant from the water pump. Make sure it is not leaking coolant. If there is evidence of leaking, the water pump is bad. You must take extreme caution when dealing with the cooling system (hot liquid under pressure; not a pleasant thought), but you can remove the radiator cap and start the engine. Check the coolant in the radiator for movement/circulation. If the water pump is functioning properly, there should be some visible sign of water/coolant circulation. The water pump may not be at fault, but with the other upgrades you made to the cooling system, some gunk (for lack of a better word) may have broken loose and clogged the ports in the water hose. You can also remove the hose at the water pump and check for anything clogging up the works. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | 1992 Chevrolet S-10
How do i drain the radiator and flush out on a 1999 chevy blazer?
open the drain valve on the bottom inside of the radiator, run the engine with the garden hose in the radiator cap, have the heater switched on high temp.  After the water comes out clean, turn off engine and let all water drain out.  Replace with 50/50 mix if distilled water and antifreeze.  Collect old antifreeze as it is very toxic and poisonous.
Mar 11, 2009 | 1999 Chevrolet Blazer
1A Auto Parts 2000 Chevy S10 Blazer GM Style Black Lug Nut Cap Set of 5 for Mod Logo
280 people viewed this question
Top 1A Auto Parts Tools & Hardware - Others Experts
Pete Bruk
Lawrence Oravetz
William Alequin
Are you a 1A Auto Parts Tool and Hardware - Other Expert? Answer questions, earn points and help others
