Question about Fuji FinePix S2 Pro Digital Camera
How do i change the shutter speed on fuji s2 pro
Im a bigner need help
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
In the P, S, and M modes, turn the command dial on the back of the camera. In the P and S modes the aperture will also change to compensate. In the A mode, turn the secondary command dial on the front to change the aperture, and the shutter speed will change to compensate.
Posted on Oct 29, 2012
  • 1382 Answers
SOURCE: Fuji FinePix S2 Pro
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Posted on Jun 25, 2010
  • 8 Answers
SOURCE: error msg fuji s2
couple of things:
I take it that "Err" shows on the display ? This can be caused by a number of things, including the aperture ring on the lense being in the wrong position. Make sure its set to the orange number. The 'err' message isnt generally shown for a power problem. If you have a DC power lead, attach that and see if you can get the camera to work.
Batteries are a nightmare for the S2.
Firstly, if looking for rechargeable AA's, you need at least 2300mAh. Maplin are doing a good deal till the end of the month on them; http://www.maplin.co.uk/Module.aspx?ModuleNo=46414
If you have the small lithium batteries in, then take them out. If the camera senses that they are in there, it will try and use them -even if they are depleted.You can replace them with CR123a batteries, but unless you want to use the on-camera flash, I wouldnt bother. DONT BUY RECHARGEABLE CR123A s !! They do not have anywhere near enough power.
Summary; Check aperture ring remove/replace CR123a (High quality replacement) Use high power AA's
let us know if this works
Posted on Sep 22, 2008
  • 11967 Answers
SOURCE: my fuji FinePix S2 Pro is processing images with a
Could be a white balance setting or you've accidentally engaged a digital filter. You could try a camera reset. Go into the setup menu and scroll to "reset". This will take you back to the default settings.
Posted on Sep 22, 2009
SOURCE: Fuji FinePix S2 Pro won't turn on
Do you remember what did they do to reset the camera ? Can you share, please ?
Posted on Dec 08, 2010
  • 21 Answers
SOURCE: How to reset to factory settings , my fuji finepix
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
Posted on May 09, 2011
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
Camera operates but produces black image. shutter
I have the same problem. Have you fixed it yet? If so, would you mind sharing what you did to fix it? Thanks!
Aug 10, 2010 | Fuji FinePix S2 Pro Digital Camera
How do you change the shutter speed on the fuji s700?
You can't manually change the shutter speed. It does change on its own when you change modes. If you want more control over shutter speed and aperture, you need to step up to a DSLR camera.
Jan 08, 2010 | Fuji FinePix S700 Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji S2 problem
Err after a shot usually means bad AAA batteries. Change to alcaline or NiMH rechargable.
Dec 27, 2007 | Fuji FinePix S2 Pro Digital Camera
Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Aug 23, 2007 | Fuji FinePix S2 Pro Digital Camera
FUJI S2 PRO
Maybe your card is already def.
Aug 08, 2007 | Fuji FinePix S2 Pro Digital Camera
Change MP to 12
If shooting RAW set the resolution to 4256 when using the raw converter. If shooting JPG's set the 4th setting on the function menu to 4256.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
S2 Pro User Questions-Focus Issue
With the camera you have, noise isn't much of an issue when pushing the ISO to 400, 800 or even 1600. Try setting at ISO 400 and change it to manual mode or shutter priority and then choose a faster shutter speed. Take some test shots. If it's still blurred, increase the shutter speed and ISO to 800 and try again.
Sep 04, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
65 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
