I can not charge the 2gb AMT MP3
To me presented 2gb AMT MP3 it worked short time then I can't charge it. Whether it is possible to charge it via the computer, whether any special charging is necessary?
  • 32,281 Answers
The MP3 player is charged using the USB cable when it is connected to the USB port of your computer.
Posted on Oct 30, 2012
5 Suggested Answers
SOURCE: just got technika 2gb mp3
solisito bajar musica de linkin par a mi mp3 audio u2
Posted on Jun 26, 2008
anujtaluka
  • 392 Answers
SOURCE: My sansa 2gb mp3 player won't turn on. When I plug
first try a software reset...press and hold the power button in on position for a minute or so then try powering up normally..if tht doesnt work,the battery wire may have snapped...you will need to open up the unit and re-solder the wire.
Posted on Sep 08, 2009
  • 899 Answers
SOURCE: charging battery
you might have a faulty charger or the battery just won't charge , if you can exchange it back at the store I would do that , but otherwise the charger would have to be tested and the battery , and if those are ok then something is wrong in the mp3 player
Posted on Oct 12, 2008
  • 7 Answers
SOURCE: How do I charge the MP3 Player?
Have you got the cable that go's between the mp3 and the computer ?. If you have then that is haw you charge up your mp3 player, you can leave it hocked up to your computer while it is charging.
Posted on Feb 23, 2010
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
I just got the mp3 player. ive been charging it but when i disconnect it from my computer it shuts off and wont turn back on. HELP!
Some older computers that have USB ports that limit the output to 5V @ .5 amp current. Depending on your MP3 player, it may not be sufficient to charge the player. This was the spec back then. Since then, new USB specs call for 5V @ 1.0 amp current - a two fold increase in current.
You may have better luck connecting to a powered USB hub instead. If you're only looking to charge the MP3 player, you don't even need to connect it to the computer. The powered hub gets powered by connecting the ac adapter / power supply to a wall outlet - instead from of the computer's power supply via mother board.
The above assumes there is a good, rechargeable battery; a functioning charger & USB port in the MP3 player and of course, a working USB cable. If any of the above is faulty, you'll never get the MP3 Player to accept a charge. You should try different computers, cables and ports if possible.
Sep 07, 2011 | Computers & Internet
Shutdown suddenly and it cant turn on
This problem can be with the battery charging in your laptop.
Try charging the battery whether it is charging or not. Try to charge it for 3 hours & then try to start the system.
Jan 24, 2011 | Computers & Internet
Silver Sylvania smp2012 2gb what kind of charger do I need for this mp3 player
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
Aug 14, 2010 | Sylvania SMP2012SL 2GB MP3 Player
I left my 2GB charging, and when I looked at it, the screen was frozen, I took out the charger, it went black, and now I can't turn it on
There could be a possibility that you've got either a defective battery or faulty components on the small circuit board inside.
What happened to your player is an indication that the battery could no longer hold a charge and/or some components became shorted.
Since most mp3 players have built-in batteries, I would suggest to contact the manufacturer and have them repair it for you.
Feb 28, 2010 | SanDisk Sansa Fuze MP3 Player
Old nano ipod 2gb is not working & makes sound when
your ipod software crashed so, you have to repair it by technician
Feb 10, 2010 | Apple iPod nano
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | Audio Players & Recorders
My AMT mp3 doesn't load
I just got one. Cute little thing at a cheap price. Plug it in and my virus checker wants to delete the program. Tell it that the program is OK and to leave it alone. In XP it put two drives on my system - a AMT CDROM drive and an AMT MP3 drive. Ignore the CDROM drive, at least at first, and copy your music files to the MP3 drive. The key to making it play does seem to be holding down the play button while flipping the power switch to ON. Having it on or off when unplugging from the computer does not seem to matter.Who knows how long to charge it at first?
Nov 06, 2008 | Audio Players & Recorders
233 people viewed this question
 Grubhead
Grubhead
