Question about Frigidaire GLER341A Electric Dryer
Very hot to touch on top
My dryer gets very hot on top on the right hand side. We have cleaned lint traps, opened up the top and vacuumed everything out but still gets extremely hot (can't lay your hand on it for long).
  • Anonymous Jan 10, 2009
    YES YES I too have this problem. Concerned it could be fire hazzard. Looking for assistance.
  • makky05 Feb 07, 2009
    Same thing for me ..not sure if we have the same type of frigidaire dryer but regardless....checked all the vents and cleaned it out..what do i do now?
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Posted on Feb 06, 2009
When i pull out the lint trap and stick my hand in as far as i can, i can feel a large buildup of lint and I don't know how to get to it
you will need to open then dryer up and with a brush(paint or another soft bristled brush) and vacuum remove all the lint, might as well clean the vent tube out, here is a website that will show you how to open it up, Good Luck Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Mar 19, 2011 | Dryers
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
Dyer really hot, not drying clothes
Is the dryer tumbling? If not, you may have a broken belt or some other drive assembly issue.
Also, turn the dryer on and go outside to the vent discharge - you should feel air coming out at a pretty good clip. If not, the vent line is obstructed and will need to be cleaned out.
Jan 07, 2010 | Dryers
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
I CAN HAVE MY DRYER ON THE HOTTEST SETTING AND IT GETS HOT BUT TAKES LIKE 3 TIMES THROUGH A CYCLE TO DRY MY STUFF
I would first pull the exhaust hose or pipe off and check for blockage or a kink. If its getting hot then its probably an air flow issue. Also make sure the lint trap is clean. Sometimes you can get the crevice attachment for a vacuum down in the lint trap area far enough to clean any excess lint out. Check where the dryer exhausts outside for a blockage like maybe birds nest or bees hive. I hope this helps.
Aug 13, 2009 | Whirlpool Dryers
Lint fell down the lint trap. How do I get it
Luckily, dryers are light. Best thing to do is pull it out until you can remove the back cover. (unplug it first) Then vacuum and clean all the dust and lint you can. This should be a yearly thing at least anyway. Replace the back plug it in and slid it back. I do mine every 6 months or so.
Jul 13, 2009 | Whirlpool Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
499 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
