Question about Canon EOS-AE-1 35mm SLR Camera
Shutter sticks on Program but not on other settings
Camera hasn't been used for many years - put in new battery - on Prgram, the shutter hangs up or something, but finally "clicks" - but if I put it on the other film speeds, it seems to work ok. Is this something I can fix or should I spend the money for someone to fix it? Camera seems in great condition otherwise, and I have several nice lenses for it too. Guy at camera shop said I should try to sell it on Craigslist for $50 or so. I can't believe it's not worth more than this.
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jul 18, 2016
Gryfox
  • 216 Answers
SOURCE: Camera turns off
Open the file door and check to see if the shutter blades look uneven, like they might have been pushed out of track. Sometimes it's simple to re-track them - other times it'll have to go to a repair shop. Another cause is the film motor wears out and has to be replaced - a job for the repair shop.
Posted on Nov 19, 2006
SOURCE: T90 shutter
Hi Tim, I had the same problem , I took it to get it repaired & was told that it needed a new shutter solinoid , the repair cost £90 5years ago, you are probably looking at around £140+ today. mine has gone again & I am reluctant to spend that sort of money on it again. If you manage to get it repaired & there are periods of time when you wont be useing it take it out periodicly & just run the shutter a few times, it helps to stop it sticking. Good luck with whatever you decide to do . regards dave.preece@ukonline.co.uk
Posted on Apr 27, 2007
cpt100
  • 154 Answers
SOURCE: Canon AT-1 (Similar AE-1) Shutter Fires Upon Advancing Film Lever
No need to look at the schematics. It only will give you a little headache. Replace Shutter release magnet (MG#3). While winding stage the Mg#3 suppose to catch the lever and any dirt or particle may prevent it. Clean it and it shoud take care of the problem. Good Luck -James. For further assistance email, go to www.camerarepairjapan.com
Posted on Mar 26, 2009
cpt100
  • 154 Answers
SOURCE: Automatic aperture setting on canon FD lenses not working on AE-1
You have a case of AE(auto exposure) Unit faulty or getting bad. It suppose to register as it move within the AE unit according to the exposure calculation but somehow it is broken. Technician usualy replace the AE unit and takes care of the problem. It can also be rebuilt if new parts are not available. This requires complete disassembly and mirror box removal. The average cost of repair probably runs around $100. Yes, "A" mode is correct for most of the shots and it was a state of art electronic system and more computerized than you think. It has 3 IC chips in there for precessing and 1 chip for the exposure. All works together for good. -James
Posted on Apr 01, 2009
pontelemon
  • 531 Answers
SOURCE: Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Posted on Apr 02, 2009
Have Minolta 440si. It was 'dormant' w/o battery for several years. Wanted to use. Loaded fresh battery and film. No shutter operation at all. But,display is visible and auto film load and rew
If it has been stored for so long, the internal battery, which maintains the settings etc and is charged from the main battery, is probably defunct.
May 25, 2017 | Minolta Maxxum 400si 35mm SLR Camera
Canon EOS 50D camera error 231
If you have another lens, try it with that lens and see if it works properly. Many times ERR 99 is caused by a failure of either the circuit or the aperture unit in the lens.
Otherwise the most common cause usually is a faulty shutter.
Jan 19, 2013 | Cameras
Camera doesn't turn on
Try to clean the corrosion off the battery contacts. If not give it to Nikon they may be a little expensive but they will restore the camera to it's original condition.
http://www.nikonusa.com/en/Service-And-Support/Nikon-Authorized-Repair-List.page
Jan 11, 2013 | Nikon F3 35mm Film Camera
Whenever I touch the operating button to meter, the "under-range LED" will not stop blinking. No shutter speeds illuminate, not even the one I have the shutter set to. The only LED's that...
Be sure your mode dial is not in the auto position. If it is, the camera will only function with the lense also locked to the auto position, which will either be the lowest aperture (highest number) or sometimes an "A" setting separate from the normal aperture settings. That's generally what this type of indication means on program/manual models - that you're trying to use manual settings, when the camera is set up for auto program exposure.
Sep 08, 2011 | Minolta X-700 35mm SLR Camera
Nikon FG. Replaced 3V battery. On the M90 setting the film advances OK. On 'program' or other settings it will only advance once and after shutter fires it will not advance until put on...
M90 is a battery independent setting - it requires no battery power to function. If it won't advance until put on M90 from other settings, then either you're not allowing for proper exposure, have the settings incorrectly set (film speed, etc), or you have shutter issues. The shutter is electronically controlled on all settings except M90. In the auto setting, your lense MUST be set to the smallest aperture (biggest number). On any other setting, you can use it however you'd like. I'd suggest unloading any film, setting the shutter speed dial to 1/125 or so, opening the back and looking thru and firing the shutter. If it's not snapping open and immediately closed, theres an issue and you need to consult a repair technician either locally, through Nikon, or through KEH Camera online.
Jun 29, 2011 | Nikon FG 35mm SLR Camera
Camera shuts off after one shot
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Sep 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
74 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
