Question about Dodge 2003 Neon SXT
Check engine oil light on - Dodge 2003 Neon SXT
    Master:
  • 444 Answers
Well check the oil then, DAAAAAAAAAAAAA.
Posted on Oct 29, 2012
Where is the oil sending unit on a 1996 mercury cougar xr7 ? Its cause my oil pressure gauge is bouncing up and down...i dont know why...can anybody please help me thank you so much
The low oil pressure warning lamp will illuminate anytime the ignition switch is turned to the ON position without the engine running. When the engine is running, the light also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
If the oil pressure light does not work, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp lights, make sure the oil pressure switch is properly grounded in the cylinder block, and if so replace the oil pressure switch. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
To diagnose an oil pressure light that stays on, perform the following:
  1. Check the engine oil level and top off as necessary. If the engine was 2 or more quarts low on oil, test start the engine after topping off the oil level and recheck the oil pressure light operation. If the light stays on, stop the engine immediately and go to the next step.
  2. Disconnect the wire at the sending unit, then turn the ignition switch to theON position. If the light remains on, check the wire from the sending unit to the gauge for being shorted to ground and repair as necessary. If the light goes out, turn the ignition switch OFF and go to the next step.
  3. Replace the oil pressure sending switch with a known good switch.
  4. Start the engine and check the oil pressure light operation. If the light stays on with the engine running, stop the engine immediately to avoid severe engine damage until the cause of the problem can be determined.
WARNING
If the oil pressure light remains on while the engine is started, stop the engine immediately. Do not operate the engine until the cause of the problem can be determined. Operating an engine with low oil pressure will cause severe internal damage.
Possible causes for an oil pressure light to stay on are:
Pinched or grounded sensor wireDefective oil pressure sending unitRestricted or severely leaking oil filterExcessive internal engine bearing clearance.Insufficient or severely contaminated engine oilBlocked oil pump pickup screen or severely worn oil pump
Mar 31, 2016 | Mercury Cars & Trucks
Check oil light stays on
Your vehicle may have an "oil level" sensor built into the oil pan. If so, and the sensor is bad, the dash will constantly tell you that the engine needs more oil even if it does not. Checking the oil with the dipstick, a minute after the engine has been turned off on level ground is always the best way to check your oil. Try scanning the vehicles computer systems to see if there are any fault codes. The warning light may also be on a timer that just needs to be reset. The "Check Oil" light should be separate from the engine oil pressure warning light. As long as the engine oil pressure light stays off, you should be ok. Checking the oil pressure with a manual gauge would be a good idea as well.
Apr 23, 2014 | 1999 Toyota Corolla
Too much oil and check engine light is now on
there is an oil light for the oil reservior, but the engine has another light which mean your engine has a problem no shyches to the oil
Aug 07, 2012 | 2001 Chevrolet Cavalier
2004 lincoln avaitor oil light comes on the engine shuts down
Does the oil light come on BEFORE the engine shuts down? I have to ask because it is NORMAL for the oil light to be on when the engine is not running. I had a customer that said the same thing just last week. After we wasted a bunch of time (which the customer ended-up paying for) checking the oil level, the oil pressure, and verifying correct oil pressure gauge, light, and sending unit operation, it turned out that the crankshaft position sensor was bad and causing the engine to shut down and it had absolutely NOTHING to do with the oil light - it was functioning as designed.
If the oil light is coming on before the engine shuts down, the first thing you need to do is check your oil level. If the oil level is OK, you need to check the oil pressure with a gauge to determine if there is an actual engine oil pressure problem or if the oil pressure sending unit, gauge or light is malfunctioning. Also, it is highly advisable to not drive the vehicle AT ALL if the oil pressure light is coming on while driving until the cause of the light coming on has been determined and repairs have been made. Otherwise, SEVERE ENGINE DAMAGE may result.
Feb 21, 2012 | Cars & Trucks
Bought car and was overfull on oil, oil light and check engine on
what kind of car? have you looked up the code? need more info
May 08, 2010 | 2004 Hyundai Tucson
Check engine light came on. Checked all fluid levels, found low oil. Added oil and need to reset check engine light
low oil would normally set off an individual warning.. either way when You topped off the oil it would automatically reset the light.. the check engine light comes on when an electrical component sends a signal, the best thing is to take your car to a qualified mechanic so he can use his scan tool to get the code from your car. It could be most anything from an O2 sensor (the typical first engine check light) to your cars computer..
Mar 25, 2010 | 2002 Mercury Grand Marquis
I have a 2000 trooper that burns oil. I let it
If the engine oil light wont go off it might be the damage is done and you need some major engine work .
Oct 03, 2009 | 2000 Isuzu Trooper
Check engine light came on due to, I think, low oil. Topped off oil. Now how do clear the check engine light?
If engine oil was causing the light to come on, after you added it the light would have gone out. Oil pressure problems will not set a computer code. Possible that the oil pressure sender is bad or there is another problem. If the engine is noisy, the problem is internal and serious...don't drive the car. If everything is fine, have your codes checked to see why the light is on. Most larger parts stores do this for free and can clear the codes after they have read them.
Sep 21, 2009 | 2000 Honda Odyssey
I have a 1992 toyota camry LE, 4 cyl. and the oil indicator light keeps flickering on and off, what is the problem. I have checked the transmission and the oil levels and they are all okay. Confused as to...
Is it an oil pressure light or an oil change light (check the owners manual) If its an oil change light it may be time to change the oil. If its an oil pressure light you could have a short to ground in the wiring or at the oil pressure sender mounted on the engine. Also are you checking the engine oil with the engine running or off. The transmission is checked with the engine running, engine oil with engine off. If it is low on oil it will intermittently flash. Also when you check the oil wait five to ten minutes after the engine stops to let the oil settle before checking or you may get false readings.
Apr 02, 2009 | 1992 Toyota Camry V6
Engine seized no oil did not get check oil or check engine light
The oil pressure warning light only comes on when oil pressure drops below 4psi at this moment there is no oil in the engine most often it does not get to this point because oil, water etc is checked every week. It could be your engine was using oil which would point to an engine fault.
Jan 21, 2009 | 2005 Mazda 3
Dodge 2003 Neon SXT Logo
Top Dodge Audio Players & Recorders Experts
J.D. Browning
J.D. Browning
kli99gunrunn
Are you a Dodge Audio Player and Recorder Expert? Answer questions, earn points and help others
