Question about Nikon Coolpix L105 12.1 Mp Digital Camera - Black
After inserting memory card the error 'this card cannot be used' has occured
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Posted on Oct 29, 2012
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
Hii....i'm using scandisk 4gb memory card in nokia
i have same
probleam in nokia 5233
May 31, 2012 | iPhone Apps
Won't recognize memory card
When this memory card error occurs on the G9, it is most often from a faulty card reader in the camera. If you need help with it, try this place: www.camerasandparts.com They just specialize in the Canon Powershots and they know these models so well. Go to their site and send them an email, I'm sure they can tell you what's going on with it. Hope they can help you with the problem, good luck.
Apr 22, 2012 | Canon PowerShot G9 Digital Camera
"Message storage memory not ready", followed by 0x80900001 error while backing up
first try to reduce the memory of phone.Because if the phone memory is almost full this could happen.Thanks for visiting fixya.
Mar 27, 2012 | Nokia mobile C2-00 Dual SIMbiosis
Each time i put my memory car in my phone that is a blackberry 9000 i get a message saying " A media card has been inserted that contains errors. To correct the errors please use a disk error-checking...
Hello.
To do that, you need a card reader. Insert your memory card into a card reader, then:
Insert the card reader into your computer's empty USB slot.
Go to "computer" or "my computer".
Right click on the drive of your card reader and choose properties.
Click the "Tools" tab then click "Check now"
Check "Automatically fix errors" and "Scan for and attempt to recover bad sectors"
Click "start" and wait for it to finish.
That should fix the errors. If it doesn't, format your memory card.
Thanks for using Fixya!
Jun 22, 2011 | Cameras
My camera is giving me a "no memory card" sign, but the card is inserted correctly. I have taken it out, cleaned it, and put it back, replaced the batteries, and everything. However, to no avail....
If the camera displays Memory card error, No Memory Card, or takes an abnormally long time to write an image to the memory card, when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. For SD card, make sure that the card lock switch is in the correct position and not stuck in-between.Try formating the memory card ,if after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Mar 19, 2011 | Canon PowerShot S51S Digital Camera
When I insert the sd memory card into my Mitsuba dc500t digital camera, it won't function until I remove the memory card. Any suggestions as to why this occurs and how to correct the problem so I can...
On MEMORY Card Problem, Make SURE its the SMALL Insert SD Card you are using & Not just a SD Card!
I Have same Camers & it should fix your Problem to use from 2 to 8 GB Memory.
Good Luck,
Dan
Apr 21, 2010 | Mitsuba DC500T Digital Camera
Kingston 2 gb i cant format showing insert a disk and then try again i want format how
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at vicky.akon11@gmail.com i will help you again take care
Mar 26, 2010 | Kingston flash memory card - 256 MB -...
Nikon Coolpix L105 12.1 Mp Digital Camera - Black Logo
97 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
