I have the HP deskjet 2510 3 in 1 printer. I have followed all the steps and installed the printer. It runs the alignment and Test page to say I have successfully installed my printer. I print okay, but when I switch the computer off and on again, and then want to print again it asks for the Installion CD and starts the whole process of installing again. what am I not doing. I have even installed as default printer but still no change when I switch off and then on again
  • 160 Answers
SOURCE: problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Posted on Jan 06, 2009
SOURCE: How can I install HP Deskjet 3745 Printer without a cd?
puede ayudarme alguien a resolver mi problema con mi hp deskjet 3745 printer
Posted on Jan 14, 2009
leroyal
  • 2120 Answers
SOURCE: Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Posted on Jan 18, 2009
SOURCE: HP psc 2110 Printer keeps
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
Posted on Jan 28, 2009
leroyal
  • 2120 Answers
SOURCE: HP Photosmart printer 3180 prints alignment page at start up
Replace all ink cartridges to get a successful alignment.
Posted on Feb 25, 2009
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
How do you run a print test for an HP deskjet F355 all-in-one printer?
This is invoked at the printer properties and set up page. Look for print a test page.
HP printers often perform poorly if hooked up using Plug and Play. Download the latest install software directly from HP, and follow directions exactly, no plug and play. All computers need the same install for networked printer (meaning not hosted and shared).
Oct 20, 2010 | HP DeskJet F380 All-In-One Printer
HP Deskjet 722c appears to print but the page is blank. New toner cartridges have been installed
If the clean test page shows streaked or broken colors, the printer or cartridges are not functioning properly. Note that HP cannot guarantee the quality of refilled or remanufactured cartridges. Follow the steps below to solve the problem:
  1. Remove and reseat the cartridges. Try printing again.
  2. Check ink levels, and if a cartridge is low on ink or out of ink, replace it and try printing again.
  3. Clean the cartridges. Depending on what printer you have, you can either print another clean test page or run a cleaning utility. Check your User's Guide for instructions. Try printing again.
  4. Clean the contacts, then try printing again. Click here to see how .
  5. Align or calibrate your cartridges (depending on what printer you have). Check your User's Guide for instructions.
  6. If none of the steps above have helped, clean the nozzle plate manually. Click here to see how .
  7. If the problem still has not been solved, replace the cartridges or service the printer. Click here to see how to decide which to do .
Feb 13, 2010 | HP DeskJet 722c InkJet Printer
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Oct 24, 2009 | HP DeskJet 845c Printer
I have HP deskjet F4288 ,print is not comming.
Try printing a self-test page... to do that please follow below instructions...
Printing a self-test page Follow these steps to print a self-test page from the control panel. Make sure paper is loaded correctly in the product before beginning the procedure.
  1. Press and hold the power button (c01346625.gif ), and then press the cancel button (c01361518.jpg ).
  2. Release both buttons. The self-test page prints.
Thank you.....
Jan 29, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer spits out blank page
This should solve this problem if you haven't already. It's real simple.
Nov 26, 2008 | HP Photosmart C7280 Laser Printer
Hp deskjet f380
I have experienced this before...
Disconnect the printer and remove the installed drivers, that is to remove the virus-infected file or a corrupt printer driver.
Now re-install the printer and the driver.
Fixya me on this one...
Feb 08, 2008 | HP DeskJet F380 All-In-One Printer
Print Stripes
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00226&lc=en&cc=us&dlc=en&product=304445&rule=42852&lang=en HP has indications that the lubricant on the printer carriage assembly tabs and the flex circuit contacts on the print cartridge can collect debris (fibers and dust), which may cause poor output. The lubricant is used to ensure that the interaction between the pen and the carriage assembly does not cause tears in the flex circuit. Refer to the following instructions to solve this issue. Cleaning the Inkjet cartridges can improve the quality of printing. If the printed page is missing lines or dots, or if it contains ink streaks, perform Procedure 1 in this section. If problems persist after performing Procedure 1, perform Procedure 2. NOTE: Use plain paper for these maintenance activities rather than more expensive specialty papers. Procedure 1: Cleaning the cartridge electrical contacts 1. Turn on the printer. 2. Open the top cover. The cartridges should move to the center of the printer. 3. Unplug the printer?s power cord from the power outlet. WARNING: Keep new and used cartridges out of the reach of children. 4. Remove the color cartridge. 5. Clean the electrical contacts (see Figure 1). Figure 1: Cleaning the cartridge electrical contacts A- Use a clean, soft, dry, lint-free cloth. B- Locate the copper-colored circuitry strip on the back of the cartridge. C- Wipe the coppers strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. CAUTION: Do not wipe the nozzle plate on the bottom of the cartridge. Wiping the nozzle plate can damage the cartridge (Figure 2). Figure 2: Do not wipe the nozzle plate 6. Remove the black cartridge. With a clean part of the cloth, repeat Step 5 with the black ink cartridge. Cleaning the electrical contacts inside the carriage assembly 1. Look for fibers or other contaminants on the electrical contacts inside the carriage assembly. The contacts in the printer can be damaged if too much pressure is applied during the wiping process. If necessary, the contacts may be cleaned by wiping them very gently with a dry, lint-free cloth (see Figure 3). Try to gently remove any visible debris within the carriage. WARNING: Make sure the printer power is turned off before cleaning inside of the printer. Figure 3: Cleaning the contacts inside the printer 2. Reinsert both cartridges. On models with cradle latches, close the cradle latch over the top of the cartridges. 3. Close the top cover. 4. Plug the power cord into the power outlet. 5. Print a test page. If the problem persists, go to Procedure 2. Procedure 2: Aligning and cleaning the cartridges Use the HP Deskjet Toolbox or Printer Assistant utility on the desktop (the utility name will depend on which HP Deskjet model is installed on the computer). NOTE: HP Deskjet Toolbox or Printer Assistant is for Windows users. HP Deskjet Toolbox: To align the cartridges from the HP Deskjet toolbox: 1. Open the HP Deskjet toolbox. The toolbox is located on your desktop in Microsoft ®) Windows XP, Me, 2000, 98, 95, and NT 4.0. In Windows 3.1x, the toolbox is located in the program group for the printer. 2. Select the Printer Services tab in the toolbox. 3. Select Cartridge Alignment and follow the steps on the screen. 4. After the alignment process is completed, perform a Cartridge Cleaning from the toolbox. 1. Double-click the HP Deskjet Toolbox shortcut (or icon) on the desktop. 2. Click the Printer Services tab. 3. Click Clean the Print Cartridges. Follow the instructions that appear on the screen HP Printer Assistant: To align the cartridges from the Printer Assistant: 1. Launch the Printer Assistant by clicking the Printer Assistant icon located on the desktop 2. Select tools and updates. 3. Go to printer maintenance. 4. Select calibrate printer. 5. Click calibrate and follow the onscreen instructions. Further instructions on calibrating the printer cartridges using the Printer Assistant can be found on document npd09616 - HP DJ 3320,3325 and 3420 series printers - how to calibrate the print cartridges After the alignment process is completed, perform a Cartridge Cleaning from Printer Assistant. 1. Select tools and updates. 2. Go to printer maintenance 3. Select clean cartridges. 4. Click clean and follow the onscreen instructions. If the problem persists, the cartridge should be replaced. If the cartridge still exhibits banding even after cleaning and priming actions in the HP Deskjet Toolbox are complete, the cartridge may need to be replaced. Verify the end for warranty date on the supply before returning it to the reseller. Typically, banding problems are most pronounced in images produced on plain paper in Normal mode. In many cases, simply changing to Best mode will alleviate the problem and produce satisfactory output. If switching modes does not result in acceptable performance, try using the cleaning steps described above. Internal test from the printer Running an internal test from the printer can perform a clean test. See document titled HP Deskjet Printers - How To Print Internal Tests for instructions on how to run internal tests. If the problem persists, replace the cartridge. Let me know if that helps. Good Luck, Tim
Mar 15, 2007 | HP DeskJet 5650 InkJet Printer
73 people viewed this question
jasbo
jasbo
