Question about Alex DM18 Rim - 26 Inch x 32 Hole Black SV
Alexrims dm18 can a rear rim be used in the front if i however change the hub and bearing but still use spokes
    Problem Solver:
  • 16 Answers
The rim should not cause any problem - but you'll need different length spokes.
Rear hubs and front hubs are different widths, have different height hub flanges, and different amounts of "dish" (offset from the center of the hub body.
If your hubs and rims are in good shape; go ahead and re-use them; but you'll need help measuring or want to use a spoke calculator online for the correct length spokes.
Posted on Nov 03, 2012
Rear wheel wobbely
Not enough info here. Is it the rim or the hub that is wobbly? If the rim is out of true (and not actually bent) the spokes can be tightened to bring it back into true. If the hub is loose then the bearings need to be adjusted. Either adjustment can be done by your local bike shop for $10-20. A broken spoke can also make the wheel go out of true, this will cost a little more to fix.
Sep 09, 2015 | Huffy 26 in. Cranbrook Cruiser Bike
Can you adjust the tension on the wheel?
What sort of tension?
Rim loose on spokes: evenly tighten the spokes to add tension ( very high skill required to keep the rim true. Pro help should be sought)
Too much wheel side play: tighten the wheel to frame axle bolt (unless the bearing is gone, then you'll need new hub bearings).
Chain tension too loose: Move the rear wheel away from the pedals by loosening the axle bolt, pulling back to remove most (but not all) or the slack from the chain. Pay attention to the alignment of the wheel in the frame. Tighten the nuts back down
Feb 17, 2015 | Cycling
Front end shakes when letting go of handlebars on 87 goldwing
Hi, Anonymous and the usual suspects are:
1. Improperly loaded motorcycle. Non-standard equipment on the front end such as heavy radio receivers extra lighting equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tires or improper front-rear tire combination.
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. The shock absorber is not functioning normally.
7. Loose wheel axle nuts. Torque to recommended specifications.
8. Excessive wheel hub bearing end play.
9. Improperly vehicle alignment.
10. Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires are out-of-round or eccentric with the hub.
13. Rims and tires are out-of-true sideways.
14. Loose spokes.
15. Shock absorber improperly adjusted.
16. Worn engine stabilizer links.
17. Damaged rear engine isolation mounts.
18. Swing arm pivot shaft improperly tightened or assembled.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
GL1200 front end wobble
Shaking in Front Tech Talk goldwingdocs com
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Jul 21, 2013 | 1987 Honda GL 1200 Aspencade Gold Wing
Yamaha RX 135 wheel wobble and handlebar Vibration
14. Loose spokes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Front end wobble gone
What may be the reason for vibration in bike at particular speed
Yamaha RX Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha
Oct 06, 2017 | Yamaha Motorcycles
Yamaha RX135 front wheel wobbling and handlebar vibration
14. Loose spokes.
Front wheel wobble
Motorcycle handlebar vibration reduction Anyone have experience or insight
http://mototh.com/files/yamaha/Spark%20T135/Yamaha_T135_Service_Manual.pdf
https://www.scribd.com/document/25643028/rx-135-5speed-manual
Oct 12, 2017 | Yamaha Motorcycles
Front end wobble on a honda sabre 1100
Hi, Tdm2020 and the usual suspects are:
14. Loose spokes.
Front End Wobble Vibration
Front End Wobble
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Mar 01, 2012 | 2004 Honda VT 1100 C2 Shadow Sabre
My back wheel is making a ticking noise when i stand up and pedal. I lubricated the cross points of the spokes and it is still making the noise. I took the tire and tube off but i'm wondering how to get to...
You may have a loose spoke or two. A rubber liner usually covers the spoke heads. If you do your own repairs, invest in a spoke tension gauge and the tool to adjust the spokes.
Jul 28, 2017 | Mavic Ksyrium Elite Wheelset
I am rebuilding a rear wheel on my son's yamaha 50cc ttr. I have completed the hub spoke and rim assembly and now need to install the bearings. Can they be hammered into place or do they need to be pressed...
it is always best to press them in . set the bearing on the hub place a piece of flat steel on top of it and a piece on the bottom of the hub use a c clamp to press it in . make sure it is going in straight!!!!!
Jul 07, 2010 | Motorcycles
How do you disassemble bearings on the rear wheel to replace bent rim?
It sounds like you are trying to remove the hub, not disassemble bearings if you are trying to replace the rim. First off, replacing the rim requires you to rebuild the wheel, meaning re-lacing the spokes and truing the wheel. Unless you are very experinced in wheel building I sugguest you purchase a new rear wheel. Not only will it cost much less but it will save you much time and headache. Your local bike shop can help you with this. Hope this helps.
Jul 19, 2009 | Cycling
Alex DM18 Rim - 26 Inch x 32 Hole Black SV Logo
132 people viewed this question
Top Alex Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Alex Cycling Expert? Answer questions, earn points and help others
