Having an hum noise in the baldwin organ model# 46C
Turn power on there is a humming sound
2 Suggested Answers
maatmartin7
  • 1210 Answers
SOURCE: my baldwin 122 organ, makes a humming sound when
A bad filter capacitor and loose grounds are in there. Is there a doctor in the house?
Posted on Sep 17, 2009
Benwin 5.1 surround sound system Humming loudly without anything pluged into it!!!
It is sad your having a problem with your
If humming can be heard on all speakers, then it could probably
be on the power supply.
If it is only on the main SUB unit, then it could be the amp itself.
But check for power supply capacitors that supplies voltages to the
amps.Check for amp output DC voltages too.
Oct 04, 2012 | Audio Players & Recorders
"60-Hertz hum that comes from
What does monitor speaker MS16 have to do with an organ? To use these on an organ you should be using DI boxes to convert to balanced lines into these speakers. Who knows what type organ you have as you did not give us a clue. There are some POOR QUALITY audio output add-ons that are foisted on people that supposedly put out line level audio from older Hammond organs... these are noisy and generate hum as they have not been engineered but instead tinkered.
Sep 02, 2011 | Behringer MS16 Monitor Speaker
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
My amplifier is making a very loud humming noise
Are you able to turn the hum up and down.If you can't then you have a leaky filter in your power supply.If you can turn it up and down then it sounds like one of your grounds are open.
Sep 25, 2010 | Audio Players & Recorders
Have an older Lowrey organ with loud hum.
Of course it is repairable.
Find a competent repair person. You did not describe the "noise". If it is 60 cycle hum, the filter caps need replacing. If it is an organ tone, then probably a key contact is stuck.
May 05, 2010 | Music
Baldwin Model 230 DE when turned on makes a loud thunk like the volume is turned way up, then when you disturb or shake the organ or stomp on the floor it makes a loud noise like if you twanged a coil...
If the organ has a reverb spring "tank" in it, that is likely where the spring sound comes from.
The initial noise is likely due to the initial unbalance of the power audio amp.
Lesser organs don't disconnect the speakers till the amps attain balance so the inrush pulses the speakers..
Mar 10, 2010 | Michael Kelly Music
Turn on the organ and get a loud hum.......
Chances are you're hearing "60-Hertz" hum that comes from poor filtering in the organ power supply. Electronic circuits need direct current (DC) but our power lines supply alternating current (AC). The power supply converts the AC to the various DC voltages needed. Parts called filter capacitors smooth out the voltage, and if they go bad or lose contact because of bad connections the result can be the hum you're hearing.
There are other possible causes, but the filtering is so common it's a good place to start. You don't give the age of this organ, but if it's one that has been around a while, it's a good bet some of those capacitors are worn out.
If you can post a follow-up with a make and model, I'll check some of the technician groups and see if anybody has service information.
Good luck and thanks for using Fixya!
Feb 11, 2010 | Music
Loud noise
nost likely the color wheel, They are famous for having a piece come off the wheel which will cause a very loud humming sound.
Jan 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My baldwin 122 organ, makes a humming sound when pluged in and no pitch change?
Sep 17, 2009 | Clarity Televison & Video
Hums when turned on-won't turn over
belt may have broke. if you are hearing a humming sound . thats the motor .whitch is good, sounds like the belt broke or slipped off.
Sep 12, 2009 | Kenmore 73952 Gas Dryer
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
