Question about Chicco Rodeo Horse Ride On
Neigh doesnt work
I replaced batteries properly and horse still doesn't neigh
Dodge caravan 1996 doesnt start
It is very hard to help you when you give no details. But if it doesn't do anything when you try to start it you probably need to charge battery or get new one. If it is trying to start and doesn't sound weak then you need to have someone look at it. It doesn't sound like you would want to do anything yourself but if its not the battery, it doesn't sound good. Good luck
May 06, 2012 | 1996 Dodge Caravan
Why won't my starter turn my engine fast enough on
bypass the battery cables with jumper cables if there bad they will not carry the amps needed to crank it
Apr 23, 2012 | Briggs & Stratton Garden
Replaced battery & pcv valve now speedomter
Under the battery tray is a common ground point. It'll have several black wires going to a connector that is bolted to the frame. Remove this bolt, clean the area up, and bolt it back in place. If the speedometer doesn't work after this, then you probably need a vehicle speed sensor VSS.
Sep 13, 2011 | 1998 Ford Escort
What is the best battery for my 2002 vrod
I would definitely go for the Harley recommended battery. HD has changed their sizes and you don't want a generic battery that doesn't fit properly or doesn't have the right amount of cranking amps
Jun 26, 2011 | 2002 Harley Davidson VRSCA V-Rod
I replaced the battery and the sirius radio doesn't work - it is stuck on aquiring signal for over 30 minuites. The owners manual says to wait at least 10 minuites and it should resync but it...
Disconnect the negative battery cable for 10 mins, then reconnect it and try. Sometimes it can lock out the Sirius unit, and by disconnecting the negative battery cable for 10 mins, clears out the whole system so it can be booted properly.
Thanks Jay!
Jun 26, 2011 | 2007 Nissan Murano SE
Dear HTC, my phone is not charging properly & not showing any display regarding the charging
replace the battery- sounds like it's completely shot. If it still doesn't try- use a micro usb cable attached to a PC- if it still won't charge/come on- the charge board is gone, and you will likely need to replace the phone
Jun 22, 2011 | HTC Touch P3450 Smartphone
Why doesnt my transmission make shifts speedomiter
First check the 10 amp fuse #1.
If fuse is good, speed sensor has failed or is disconnected. Check connection. If connection is good, replace sensor.
Sensor is mounted on transaxle output. It should have a 3-wire connector on it with one yellow, one orange, and one black wire, as shown in diagram below.
Please let me know if you have questions.
Oct 06, 2010 | 1992 Honda Accord
Furreal Pony neighs like a broken record
I had the exact same problem, and all I did was replace the batteries. It worked right again! I just knew the kids had broken the neck of it. It sort of slings to the left and neighs over and over again. BATTERY ISSUE :) The instruction manual should tell the consumer this. Hope this helps!
Dec 29, 2008 | Hasbro Fur Real Friends Smores Pony
Chicco Rodeo Horse Ride On Logo
22 people viewed this question
Top Chicco Toys Experts
ray gallant
Are you a Chicco Toy Expert? Answer questions, earn points and help others
