Question about Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness
Film stuck in GBC pinnacle 27
Film is stuck around the roller
We have a slit in the silicone red rollers on the GBC Ultima 65 Laminator. Can we still use it or do the rollers need to be replaced before use?
You may have some issues with the film bonding where the slits touch it. The heat rollers are rather expensive(approx. 300.00 each) , so you make the call. Do not try to cut any jammed film off of the rollers with a sharp object. Also, don't try to peel off film that is stuck to the rollers. Let the laminator warm up a little to melt the glue on the film. It should be easy to pull the film off then. If you try to pull it off cold it will remove chunks of the roller, which will cause pitting and poor adhesion.
Mar 30, 2017 | Gbc Office Equipment & Supplies
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Our machine is starting to squeal when working what do we do
There isn't anything you can do, those machines are screamers. sometimes they start screaching right away, sometimes it takes a few rolls of film run through before they start, but they ALWAYS start to scream, sooner or later. it becomes loud enough that some people refuse to use it because they think its coming apart. not my favorite.
Sep 18, 2014 | Gbc Pinnacle 27 Ezload Roll Laminator, 27...
Pinnacle er-1
left hand side cover is probably off and excess light is getting onto the motor speed sensor. put the side cover back on and try it, most likely that will fix it. could also be the set screw on the right side is loose, error 1 means you have a speed problem. check gears and chain. only other part that has caused this in the past is the keypanel.
Sep 15, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Laminate Film Disconnected
Un-coil the lower roll and feed it through by hand.
Dec 06, 2013 | Gbc HeatSeal H425 Laminator
Film is wrapping around bottom roller instead of going out. how do I get it unwrapped?
Get a scotch brite general purpose pad, be sure to let machine cool down before you start to cleaned roller. And you can thread your laminate film.
Sep 03, 2013 | Gbc HeatSeal Ultima 65 Laminating System
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
Gbc ® Pinnacle 27 Two-Heat Roll Laminator, 27" Wide, 3ml Maximum Document Thickness Logo
122 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
